Hvac delete and insulation
Do you guys remove all this plastic stuff - and if I do will it get too hot to have just steel under there everywhere?
This is a drag race only trailer car.
Thanks
Jason
Thanks
Jason
I kept the plastic and made my own plate out of aluminum. I'm also wondering if I should throw something on the plate for insulation. I probably will soon either way, it's awfully close to that header.
Thanks guys I think I will keep that firewall plastic then, for the few pounds it is it will be nice to not melt stuff.
Did you use the same bolts that you took out for your plates or new bolts and nuts?
I used the 4 bigger bolts that bolt to the firewall from the inside and then just got enough nuts, bolts, and washers from the hardware store to fill the rest of the holes.
Ok rip away it is Thanks for posting what I wanted to hear
Do you mean I can remove everything under the drivers feet too?
I just got a cheap fleabay piece should be here any day.
