trans issues after LS swap. clutch not disengaging
i did a LS swap into my '94 firebird and i'm having some issues with the clutch not disengaging. it's a LT1 T56 that's converted to a LS1 T56 (front plate, bell housing, input, race, bearing), it's got a brand new OEM slave and master, TICK bleeder, McLeod Clutch Line.
it goes into all the gears but it's very hard, you almost have to slam it into place. The clutch pedal sits lower than the gas and brake peddles.
do i need LS1 peddles? we're almost positive there is no air in it, we've done millions of pump pump hold bleeds, used a mity vac, and used a nematic brake bleeder on it.
Moderator
Received 1,852 Likes
Did you measure the distance from the clutch fingers to the throw-out bearing? You may need a shim. https://ls1tech.com/forums/manual-tr...need-shim.html
Moderator
