Forgive me for the non LSX build...
Old 02-18-2010, 04:18 PM
'Trust''s Avatar
Default Forgive me for the non LSX build...
Had to share somewhere though. The car is currently under the knife, should have it back early next week. XP Racing in OKC is doing the build (same place that built the T/A). I'll update it as they update me.
The car:
The list:
Plate system with 15lb bottle.
http://www.nitrousoutlet.com/catalog...5&product=3542
Digital progressive controller with TPS activation and windowswitch.
http://www.nitrousoutlet.com/catalog...3&product=4004
Switch panel.
http://www.nitrousoutlet.com/catalog...7&product=3242
Remote opener.
http://www.nitrousoutlet.com/catalog...=23&section=77
Dedicated fuel system.
http://www.nitrousoutlet.com/catalog...3&product=2835
Nano.
http://www.nitrousoutlet.com/catalog...1&product=2873
The progress:
Originally Posted by Brett@XP-Racing
Been working on a Nitrous Install.......and thought I'd let you guys see how it was going. I will keep the thread updated as more progress is made....waiting on some fittings to arrive and I am spending my day wiring. The kit will consist of:
*Custom Nitrous Outlet dual plate system.
*15 lb bottle.
*Competition NANO System (supports up to 550hp).
*Custom Bottle Mount.
*Remote Bottle Opener.
*Custom switch panel.
*Nitrous Outlet Dedicated Fuel System.
*Dual Purge.
*Nitrous Outlet Progressive Controller.
The first thing I did was make the lines for the plates. Because the Viper uses dual throttle bodies, the lines must be exactly even and centered to insure the nitrous and fuel hit the cylinders at the exact same time.
I made a template for the bottle mount out of cardboard and traced it on to a sheet of plywood.......all the edges were cut at a 45* to insure a flush fit.
Here are the bottles mounted on the plywood......I have to get everything mocked up before I carpet the board.
Then I drilled access holes to run the switch panel wiring....
I'll keep it updated!
Old 02-18-2010, 04:27 PM
SkullV's Avatar
That is going to be SO sweet, I love the individual plates too. Can't wait to see more!
Old 02-18-2010, 04:31 PM
'Trust''s Avatar
Thanks, I'm excited! I'm hoping somewhat that we can control the torque spike with the progressive, if so, the car will get every bit of the 250's, otherwise it'll be limited to the 200's because of torque. Bone stock GTS' on the 200's make ~620RWHP and 890RWTQ, much more torque and you're pushing the limits of the motor.
Old 02-18-2010, 04:34 PM
camscam02's Avatar
Banned!!!
Jk, looks sweet, should be a ton of fun!
Old 02-18-2010, 04:48 PM
JoeyGC5's Avatar
you've got one of my exact favorite cars, a Blue 97GTS with CCW classics
Should be fun with the added hit also.
Old 02-19-2010, 10:05 AM
'Trust''s Avatar
Update:
Update:
Spent most of Wednesday making a wiring diagram for the system incase there is ever a problem down the road, we know what color wire goes where, then had to stop and tune a car I had scheduled..........Today, I wired up the switch panel and the remote bottle opener. Everything has quick disconnect connectors and so the system is completely removable (should Reza ever decide to take it off the car).
Back of the switch plate:
Quick disconnects from the switch plate. The wires that run to the front of the car are on one connector, and the wires for the rear are on the other.
We mounted the dedicated system using rivits, they provide a much cleaner look than sheet metal screws.
We also drilled a hole in the firewall to run the nitrous feed line from the cabin to the solenoids.
Old 02-19-2010, 10:10 AM
06 6.0 GTO's Avatar
Very impressive. hope everything works out for you.
Beautiful car by the way.
kinglt-1's Avatar
Man thats going to be sick, nice car!!
Old 02-19-2010, 10:15 AM
WSsick's Avatar
holy **** thats alot of torque! cant wait to see this thing in action.
Old 02-19-2010, 10:20 AM
'Trust''s Avatar
Thanks man!
Fingers crossed!!
Me either, I just hope the clutch holds. They are suppose to, but we'll see. I'm not talking myself out of needing a clutch, just want to see what it does on the dyno!
Old 02-19-2010, 04:18 PM
Chris@NitroDaves
Guest
Posts: n/a
Very nice build you got going there.
When Brett is done shoot us some pics over so we can put on the site.
Old 02-19-2010, 06:35 PM
'Trust''s Avatar
Cool man, definitely will! I appreciate you helping out with it on the phone!
Old 02-19-2010, 07:10 PM
RsSean's Avatar
Nano is the ****! Hooked one up the other night and what a differance. That swtich panel looks super clean, best thing is it is not bulky. Nice can't wait to see the final results
Old 02-20-2010, 05:04 AM
BSmiff's Avatar
This is going to be good. Youre going to hurt a dyno with that thing haha
Old 02-20-2010, 07:25 AM
registered user
ScreaminRedZ's Avatar
Very nice! I'm definitely curious to see how it does. Are you going to run it at the track once it's complete? What are you going to do for traction? I'm also curious to see if it loses anything NA on the nitrous tune.
Old 02-20-2010, 11:01 PM
RS_SS69's Avatar
Totally badass Trust! I dont think you will ever have a problem posting non-lsx stuff here with your history. Cant wait for numbers and track times.
Old 02-23-2010, 08:53 AM
DopdBrd's Avatar
It should run 13's.....LOL
Clean install man, can't wait to see the finished project.
Old 02-23-2010, 09:11 AM
'Trust''s Avatar
A little update, they ran the line through the car pretty nicely, it runs under the intake so all you can see in the engine bay is the plates, the solenoids and a tiny bit of line. All they need to do is install the progressive and wire the standalone and it is ready to test. After that it's installing the VEC III (engine management, plug and play mostly) and it goes on the dyno.
Haha, only with a good tire and some luck!
Old 02-24-2010, 10:08 AM
00SS4780's Avatar
Lookin great so far!
Old 02-24-2010, 05:44 PM
Canbarelygo's Avatar
i dont make it up to the city super often but ill definately make a trip up there to see this thing on the street.
im am sorta curious tire wise as well because ive heard those vipers get nasty with some juice and make monster torque as the shot goes up.
any plans on a tire for everyday driving and still hooks decent when ya wanna thrash it a bit?
