Timing in the top/left. How much just off idle?
Old 10-13-2005, 01:29 PM
GuitsBoy's Avatar
Default Timing in the top/left. How much just off idle?
Hi Guys. Ive been really hacking up my timing tables trying to get rid of my low rpm low load bucking with my f-13 cam. Ive got my idle cells right at 30º timing, and immediately after them, it ramps up to around 40º. The top left corner of my table looks like this:
30 30 30 35 39 39 40 40 41 42 43
30 30 30 34 38 38 39 39 41 42 43
30 30 30 33 35 36 37 38 40 41 43
28 28 28 31 34 35 36 37 39 40 41
26 26 26 29 33 34 35 36 38 39 40
25 25 25 28 30 32 34 35 36 38 39
23 23 23 26 29 31 33 34 35 37 38
Its taken away some of the bucking but occasionally I still catch a bit of it. Both the high and low octane tables, plus both base timing tables, and the max torque timing table all mirror the same values. What can I do to get rid of the remaining bucking? Should I put even more timing in? How much is too much? The cam is a 230/232 .595/.585 112 +4
Thanks! -Tony
Old 10-13-2005, 02:25 PM
bowtieman81's Avatar
As you know we are chasing the same thing. I have some experimenting going right now with some help, will keep you posted.
Old 10-16-2005, 08:47 AM
NAVY's Avatar
Email me your file and i'll take a look at it. (cia_navl@yahoo.com )
Old 10-16-2005, 09:54 AM
Moderator
jimmyblue's Avatar
Here is my timing table (entire). Note that the uppermost
left is decel only for me, my idle CylAir is about .17, between
3rd and 4th row and idle is 700RPM (between 2nd & 3rd
column).
I did not push on the idle-range cells the way I did on
PT/FT spark.
18.98901 22.00000 25.01099 28.00000 30.00000 33.01099 36.00000 38.00000 40.00000 41.01099 41.01099 42.00000 42.00000 42.00000 42.00000 42.00000 42.00000 42.00000 42.00000 42.00000 41.01099 41.01099 41.01099 41.01099 41.01099
20.00000 22.98901 26.00000 29.01099 30.98901 34.00000 37.01099 38.98901 40.00000 41.01099 42.00000 42.00000 42.00000 42.00000 42.98901 42.98901 42.98901 42.98901 42.98901 42.00000 42.00000 42.00000 42.00000 41.01099 41.01099
21.01099 24.00000 26.98901 30.00000 32.00000 34.98901 37.01099 38.98901 40.00000 41.01099 42.00000 42.98901 42.98901 42.98901 42.98901 42.98901 42.98901 42.98901 42.98901 42.98901 42.00000 42.00000 42.00000 42.00000 42.00000
22.00000 25.01099 26.98901 30.00000 33.01099 34.98901 37.01099 38.98901 40.00000 41.01099 42.00000 42.98901 42.98901 42.98901 42.98901 42.98901 42.98901 42.98901 42.98901 42.98901 42.00000 42.00000 42.00000 42.00000 42.00000
22.00000 25.01099 28.00000 30.00000 33.01099 34.98901 37.01099 38.98901 40.00000 41.01099 42.00000 42.00000 42.00000 42.00000 42.00000 42.00000 42.00000 42.00000 42.00000 42.00000 42.00000 42.00000 42.00000 42.00000 41.01099
22.98901 25.01099 28.00000 30.00000 33.01099 34.98901 37.01099 38.98901 40.00000 41.01099 42.00000 42.00000 42.00000 42.00000 42.00000 42.00000 42.00000 41.01099 41.01099 41.01099 41.01099 41.01099 41.01099 41.01099 41.01099
22.98901 25.01099 28.00000 30.00000 32.00000 34.00000 36.00000 38.00000 38.98901 40.00000 41.01099 42.00000 42.00000 42.00000 42.00000 41.01099 41.01099 41.01099 41.01099 41.01099 41.01099 41.01099 41.01099 41.01099 40.00000
22.98901 25.01099 26.98901 30.00000 32.00000 33.01099 36.00000 37.01099 38.00000 38.98901 40.00000 41.01099 41.01099 41.01099 41.01099 41.01099 41.01099 41.01099 41.01099 41.01099 41.01099 41.01099 41.01099 41.01099 40.00000
22.00000 25.01099 26.98901 29.01099 30.98901 32.00000 34.00000 36.00000 37.01099 38.00000 38.98901 40.00000 40.00000 41.01099 41.01099 41.01099 41.01099 41.01099 41.01099 41.01099 41.01099 41.01099 41.01099 40.00000 40.00000
22.00000 24.00000 26.00000 28.00000 30.00000 30.98901 33.01099 34.00000 36.00000 37.01099 38.00000 38.00000 38.98901 40.00000 40.00000 40.00000 40.00000 40.00000 40.00000 40.00000 40.00000 40.00000 40.00000 38.98901 38.98901
21.01099 22.98901 25.01099 26.98901 28.00000 30.00000 30.98901 32.00000 34.00000 34.98901 36.00000 36.00000 37.01099 38.00000 38.00000 38.00000 38.00000 38.00000 38.00000 38.00000 38.00000 38.00000 38.00000 38.00000 38.00000
20.00000 22.00000 24.00000 25.01099 26.98901 28.00000 30.00000 30.98901 32.00000 33.01099 34.00000 34.98901 34.98901 36.00000 36.00000 36.00000 36.00000 36.00000 36.00000 36.00000 36.00000 36.00000 36.00000 36.00000 36.00000
18.98901 21.01099 22.00000 24.00000 25.01099 26.00000 26.98901 29.01099 30.00000 30.98901 32.00000 33.01099 33.01099 34.00000 34.00000 34.00000 34.00000 34.98901 34.98901 34.98901 34.98901 34.98901 34.98901 34.98901 34.98901
18.00000 20.00000 21.01099 22.00000 22.98901 24.00000 25.01099 26.98901 28.00000 29.01099 29.01099 30.00000 30.98901 32.00000 33.01099 33.01099 33.01099 33.01099 33.01099 33.01099 33.01099 33.01099 33.01099 33.01099 33.01099
17.01099 18.00000 20.00000 21.01099 22.00000 22.98901 24.00000 25.01099 26.00000 26.98901 26.98901 28.00000 29.01099 30.00000 30.98901 30.98901 30.98901 32.00000 32.00000 32.00000 32.00000 32.00000 32.00000 32.00000 32.00000
16.00000 18.00000 18.98901 20.00000 20.00000 21.01099 22.00000 22.98901 24.00000 25.01099 26.00000 26.98901 26.98901 28.00000 29.01099 29.01099 29.01099 30.00000 30.98901 30.98901 30.98901 30.98901 30.98901 30.98901 30.98901
14.98901 16.00000 17.01099 18.00000 18.00000 18.98901 20.00000 21.01099 22.00000 22.98901 22.98901 24.00000 25.01099 26.00000 26.98901 26.00000 26.98901 28.00000 28.00000 29.01099 29.01099 29.01099 29.01099 29.01099 29.01099
14.00000 14.98901 16.00000 17.01099 17.01099 18.00000 18.98901 20.00000 20.00000 21.01099 22.00000 22.98901 22.98901 24.00000 25.01099 24.00000 24.00000 25.01099 26.00000 26.98901 26.98901 26.98901 26.98901 26.98901 26.98901
13.01099 14.00000 14.98901 16.00000 17.01099 17.01099 18.00000 18.98901 18.98901 20.00000 21.01099 21.01099 22.00000 22.98901 22.98901 22.98901 22.98901 24.00000 25.01099 25.01099 25.01099 25.01099 25.01099 25.01099 25.01099
13.01099 14.00000 14.00000 14.98901 16.00000 16.00000 17.01099 18.00000 18.00000 18.98901 18.98901 20.00000 21.01099 22.00000 22.00000 22.00000 22.98901 22.98901 22.98901 22.98901 22.98901 22.98901 22.98901 22.98901 22.98901
10.98901 12.00000 13.01099 13.01099 14.00000 14.98901 14.98901 16.00000 16.00000 17.01099 17.01099 18.00000 18.98901 18.98901 20.00000 20.00000 20.00000 20.00000 20.00000 20.00000 20.00000 20.00000 20.00000 20.00000 20.00000
10.00000 10.98901 12.00000 13.01099 13.01099 14.00000 14.00000 14.98901 16.00000 16.00000 17.01099 17.01099 18.00000 18.00000 18.98901 18.98901 18.98901 18.98901 18.98901 18.98901 18.98901 18.98901 18.98901 18.98901 18.98901
10.00000 10.98901 12.00000 12.00000 13.01099 13.01099 14.00000 14.00000 14.98901 14.98901 16.00000 17.01099 17.01099 18.00000 18.00000 18.00000 18.00000 18.00000 18.00000 18.00000 18.00000 18.00000 18.00000 18.00000 18.00000
9.01099 10.00000 10.98901 12.00000 12.00000 13.01099 13.01099 14.00000 14.00000 14.98901 16.00000 16.00000 17.01099 18.00000 18.00000 17.01099 17.01099 17.01099 17.01099 17.01099 17.01099 17.01099 17.01099 17.01099 17.01099
9.01099 10.00000 10.98901 10.98901 12.00000 12.00000 13.01099 13.01099 14.00000 14.98901 14.98901 16.00000 17.01099 17.01099 18.00000 17.01099 17.01099 17.01099 17.01099 17.01099 17.01099 17.01099 17.01099 17.01099 17.01099
9.01099 10.00000 10.00000 10.98901 10.98901 12.00000 12.00000 13.01099 13.01099 14.00000 14.98901 16.00000 17.01099 17.01099 17.01099 16.00000 16.00000 16.00000 16.00000 16.00000 16.00000 16.00000 16.00000 16.00000 16.00000
8.00000 9.01099 10.00000 10.00000 10.98901 10.98901 12.00000 12.00000 13.01099 14.00000 14.98901 14.98901 16.00000 17.01099 17.01099 16.00000 16.00000 16.00000 16.00000 16.00000 16.00000 16.00000 16.00000 16.00000 16.00000
8.00000 8.00000 9.01099 9.01099 10.00000 10.00000 10.98901 10.98901 12.00000 13.01099 14.00000 14.98901 16.00000 16.00000 16.00000 14.98901 14.98901 14.98901 14.98901 14.98901 14.98901 14.98901 14.98901 14.98901 14.98901
6.98901 6.98901 8.00000 8.00000 9.01099 9.01099 10.00000 10.00000 10.98901 12.00000 13.01099 14.00000 14.98901 14.98901 14.98901 14.00000 14.00000 14.00000 14.00000 14.00000 14.00000 14.00000 14.00000 14.00000 14.00000
Old 10-16-2005, 10:53 AM
GuitsBoy's Avatar
I emailed you a copy of the file. I also posted it for you or anybody else who wants to critique it and/or point me in the correct direction.
http://www.ihearyou.com/~tony/tuning/10-16-05_a.bin
Please note that this is not a polished file by any stretch. Im still experimenting to see what helps and what dosnt. Im still playing around with the spark tables but lately ive been looking at fueling to eliminate the bucking. Most recenly I started lowering the o2 rich/lean switchpoints because my headers really cool off the o2 sensors. I also bumped up the gain a little. I also enlarged the integrator delay because the o2 sensors with headers are located further down stream. Raising the switchpoints seemed to help with the bucking but i think its more of a coverup, so i lowered them all from stock to make the o2 sensors more accurate. Now my part throttle seems to be much more snappy, but the bucking is still there.
Thanks for all the help guys!
Old 10-16-2005, 12:55 PM
soundengineer's Avatar
lower?? I've had to raise the swith points on all the cars I've done with headers to get the fueling correct
Old 10-16-2005, 01:05 PM
GuitsBoy's Avatar
See, Ive heard conflicting information on how the cold actually affects the o2 sensors.
Some say that a cold o2 sensor reads rich, meaning that a normal reading of stoich would result in a voltage of higher than 450 mv. Just as a WOT airflow of 12.8:1 results in 900 mv.
Others say that cold o2 sensors actually read lower than 450 mv at stoich, and that the computer sees this as a lean condition and overcompensates thus resulting in the rich condition.
I chose to follow the second idea simply because the stock bin has lower switchpoints at low airflow modes. I figured the stock exhaust manifolds would be cooler at low airflow than they would be at higher airflow.
Please let me know which one is actually correct here.
Thanks,
-Tony
Old 10-16-2005, 01:55 PM
Moderator
jimmyblue's Avatar
The maximum output voltage first increases when
coming up from cold, as the chemical cell first
overcomes leakage losses, then decreases w/ temp
as you go up from there. What you're tying to deal
with is the low end, where a current-starved
sensor input might fail to get over half a volt.
But anywhere in the warmed up range the sensor
will switch abruptly through 0.5V and picking 0.3,
0.4 or 0.6 will make only a point or two difference
in a narrowband loop's center AFR.
Then again, a sensor that's failing to put out 0.5
is probably only another 50-100 degrees of exhaust
heat from failing to cross 0.4 either. The real solution
to these problems is to fix the heat loss, not crutch
the sensor electronics at the back end.
Old 10-16-2005, 02:04 PM
GuitsBoy's Avatar
Thanks jimmyblue. Its not that the sensors are stuck towards the bottom at low airflow. The sensors are swinging well past 500 mv. Theyve always worked correctly, Im just trying to get them to be a little more accurate.
Old 10-17-2005, 07:42 AM
Any luck with solving the bucking? I did some messing this weekend and have not gotten it yet. I don't know about you, but when the bucking starts it sometimes gets steadily worse until you give it some gas or push the clutch in.
FWIW, I have similar timing as you posted above. Has not cured the bucking, but man it woke teh car up down low. First gear just spins everywhere now.
Old 10-17-2005, 07:54 AM
GuitsBoy's Avatar
nope, no real cure for the bucking as of yet. Its always the worst in a slow second gear right hand turn. When I can get rid of bucking there, ill consider it gone. But like you said, off idle response is nice now.
Old 10-17-2005, 08:24 AM
SideStep's Avatar
I do not know the history of your problem, so I am going to ask about your VE tune. Is it dead-on??? I ran a F13 (112+4) this summer and had bucking until I got my VE table dialed in...
Old 10-17-2005, 08:39 AM
My VE table is dead on except in upper left area (like 800-1600 rpm, 30-50 MAP; my LTFT values are in the -5 to -12 range, but I have adjusted VE twice to get them closer to 0 and they have not changed
Other than that my VE table is excellent, nearly all 0, with a couple -1 values.
Old 10-17-2005, 09:00 AM
GuitsBoy's Avatar
I also keep my VE table as spot on as possible. I have all 0 and -1's, even in the uppse left. Although every time I change my o2 switchpoints my low rpm low map cells come off target a bit until I re-tune the VE table again. In any case, my VE table hasnt helped bucking much.
Old 10-17-2005, 03:03 PM
Hey Guitsboy, can you send me your secondary VE table in an excel file. I would like to compare if you don't mind.
email: bowtieman81@aol.com
Old 10-17-2005, 03:11 PM
GuitsBoy's Avatar
Sorry man, I dont have a secondary VE table. Its a 2002. A few posts up I linked to my .bin file.
