The Ultimate LT1-Newbie FAQ
Old Mar 29, 2005 | 11:26 PM
Vendetta's Avatar
Default The Ultimate LT1-Newbie FAQ
Due to the cluttering that's starting to form at the top of the forum with all of the stickies, I'm going to begin a vast compilation of LT1 FAQ material. Will probably take me quite a while, but I will list it all here as I post it up. Make sure you check this area regularly if you're a new user!
TABLE OF CONTENTS
                        I'd like to say thanks in advance to all of you guys who contribute to this forum even though it's a part of an LS1 community. Your help is much appreciated by all of us.
                        Also a big thanks to Jerami (JRP) since I stole most of his ideas and his layout from the Newbie forum.
                        Old Mar 29, 2005 | 11:29 PM
                        Vendetta's Avatar
                        BASIC LT1 SPECS
                        Block and Basics
                        Displacement: 350 cubic inches, 5733 cubic centimeters, 5.7 liters
                        Block Material: Cast Iron
                        Main Bearings: 2-Bolt Centers and Ends (The Corvette LT1/LT4 had 4-bolt mains)
                        Stroke: 3.48"
                        Bore: 4.00"
                        Compression Ratio: 10.4:1
                        Combustion Chambers: 54 cubic centimeters
                        Factory Redline Rating: 5700 Rotations Per Minute
                        Bottom End
                        Piston Material: (10159437) Eutectic Aluminum/Silicon Alloy
                        Connecting Rod Material: (10108688) Powdered Metal
                        Crankshaft Material: (12556307) Cast Iron
                        Top End and Valvetrain
                        Cylinder Heads: (10168448) Cast Aluminum, 2 valves per cylinder/16 valves total, ~212 CFM flow (Impala SS and Caprice heads were made of cast iron*)
                        Valve Diameter: (intake- 10241743, exhaust- 12550909) 1.94 intake, 1.50 exhaust
                        Valve Overlap: 41*
                        Valvesprings: (10206040) 85 lbs, seated
                        Camshaft Specs (12551705): 205/207 duration @ 50*, .447/.459" lift, 117 Lobe Seperation Angle
                        Rocker Arms: (10089648) 1.5:1 Stamped Steel
                        Timing Chain: (10128485) Powdered metal butt link
                        Intake and Fuel Delivery
                        Fuel Delivery: Electronic Fuel Injection, sequential port
                        Injector Size: (17124248) 3.0gps, 22lbs/hr speed density (1992-1993), 24lbs/hr mass airflow (1994-1997)
                        Throttle Body: 48 millimeter twin butterfly
                        Intake Manifold: (12552137) Aluminum
                        Factory Power Ratings
                        92-96 LT1 Corvette: 300bhp, 330lb-ft
                        1996 LT4 Corvette: 330bhp, 340lb-ft
                        1992 LT5 Corvette: 375bhp, 370lb-ft
                        93-95 LT5 Corvette: 405bhp, 385lb-ft
                        93-95 LT1 F-Body: 275bhp, 325lb-ft
                        96-97 LT1 F-Body: 285bhp, 325lb-ft
                        96-97 WS6/SS: 305bhp, 335lb-ft
                        93-97 Firehawks: 315bhp, 340lb-ft
                        Factory LTX Camshaft Specifications**:
                        1992 Y-body: 205/207 0.451/0.450 lift 117 LSA
                        1993-1995 Y-body, F-body: 202/207 0.450/0.460 lift 116 LSA
                        1994-1996 B-bodies (including L99 4.3L): 191/196 0.418/0.430 lift 111 LSA
                        1996 Y-body, 1996-1997 F-body: 200/207 0.447/0.459 lift 117 LSA
                        1996 Y-body, F-body LT4: 203/210 0.476/0.479 lift 115 LSA
                        * Cast iron heads are known to flow better, but are also more prone to heat-soak than aluminum heads.
                        ** Thanks to Metalbeast for these specs
                        Further discussion of these specifications can be found here.
                        Old Mar 29, 2005 | 11:35 PM
                        Vendetta's Avatar
                        BASIC BOLT-ONS
                        Intake Components
                        Moroso, K&N, SLP, IRS, Hypertech(Air Foil), etc.
                        Cold Air Intake(CAI) - $150 to $300 - Replaces the stock Air Box and Filter with larger filter(K&N Usually) and better flowing intake tract that connects to the MAF Sensor.
                        Mass Air Flow Sensor Ends(MAF Ends) - $50 to ? - Replaces stock MAF ends and Maf screen with a ported set of MAF Ends that still utilize the original MAF Sensor.
                        1LE Elbow - Approx $70 - Replaces the stock unit with a smoother unit that does away with the silencer(the donkey dong on the bottom of the stock elbow).
                        Air Foil/Air Charger - $30 to $60 - Bolts to the front of the Stock Throttle Body to smoothen out the airflow going into the intake.
                        Throttle Body (aka a "TB") - Starting around $320 for a 52MM or 58MM BBK which is the most often purchased TB, or you can port them yourself free of charge if you have a dremel at your disposal.
                        Exhaust Components
                        Hooker, Mac, BBK, SLP, Borla, Flowmaster, FLP, Edlebrock, Magnaflow, Custom (Kooks)
                        Catback Exhaust - $250 to Custom - A performance exhaust system that starts after the catalytic converter and generally includes all pipes, the mufller, and tips.
                        Headers - $300 to Custom - Shorties include Hooker, Mac, Edlebrock, BBK, etc. and Longtubes include Hooker, FLP, etc. and custom setups from Kooks and other manufacturers.
                        Y-Pipes - $250 to Custom - Y-Pipes are generally included in Shorty Header systems but not always and are rarely included in Longtube Header systems. Y-Pipes are shaped like a "Y" and connect both header collectors to the I-Pipe which connects to the Muffler System.
                        Cutout/Electric Cut-Out - $30/$200 - Exhaust dump best placed infront of the cats or as far down the I-Pipe as possible if you wish to stay emmisions legal.[/SIZE]
                        Suspension
                        BMR, ALSTON, HOTCHKIS, LAKEWOOD, LG, ETC
                        Sub-Frame Connectors (aka "SFCs") - $All Ranges - Tube'd or Box'd versions that connect the front section of the car's frame to the rear section of the car's frame providing a more stable, tighter, and properly handling ride.
                        Sway Bar Kits - $350 to ? - Keeps the car from "rolling" in the turns.
                        Lower Control Arms (aka "LCAs") - $95 to Custom - Connects the axle to the rear subframe. Aftermarket LCA's replace the stock stamped steel. LCA's with more solid/rigid units that are generaly bought to greatly enhance straight line performance. Generally used to eliminate wheel-hop as well.
                        Panhard Rod (aka a "PHR") - $100 to Custom - Used to align the rear end once the car has been lowered or heavily modified suspension wise. Greatly increases the cornering stability and helps keep the back end of the car centered under hard cornering situations.
                        Torque Arm - $150 to $600 and up - One end connects to the rear end of the transmission and the other connects to the Rear End housing. Helps keep the car "planted" without robbing the car of Tq and HP.
                        Rear Gears
                        GM, Motive, Richmond, Moser, Strange, etc.
                        3.23:1, 3.42:1, 3.73:1, 4.10:1 - $179 to $300 - You can greatly increase a vehicles acceleration while only slightly reducing top speed by changing the gear ratio from a taller gear (3.23:1) to a shorter gear (3.73:1).
                        Misc.
                        160 Degree Thermostat - $20 - A thermostat which opens at a lower temperature allowing the car to run cooler, usually used in conjunction with a Hypertech Power Programmer or a Fan Switch that allows you to turn the fans on earler as well.
                        Underdrive Pullies(Crank and Alternator) - $60 to $100 - These pullies are resized and replace the stock pullies allowing the motor to free up some lost HP that was formerly used to turn the accessories. The pullies free up HP by turning the accessories slower requiring less effort from the motor.
                        MSD Ignition Box(MSD6A or MSD6AL) - $150 to $250 - Provides a stronger and more accurately timed spark to more efficiently burn mixed gases in the combustion chamber.
                        Maunal Fan Switch - Free to $75- Used to manualy turn the radiator fans on and off when needed. TO do so for free, all you need is an automotive relay, switch, and some wire....10bucks at radioshack
                        Short Throw Shifters For M6 Cars (B&M, Hurst) - $160+ - Installed to provide a shorter and more accurate shift.
                        Hypertech Power Programmer - ~$330+ - Used to lower fan activation temperatures, rev limiters, fuel curve, gear ratio's, change in tire size, etc.
                        Tunercat/LT1edit - An alternative to hypertech that will allow you to manualy adjust a larger variety of settings within the PCM.
                        Weight Loss - FREE!!! - Any thing that you can do without on the car and are willing to yank out. Weight is the ultimate name of the game and you will see the most gains from weight loss..weight is 90% of racing.
                        The most often asked question is "what are the first mods I should do to increase my car's performance?". Basically, all a car wants/needs to make more power is air. Increase the amount of air going into and out of the motor and you will increase the power output. Best way to do this is to increase the volume of air going into the motor while also maintaining a high air velocity. The first few mods installed on the car should be purchased to accomplish this. First and foremost, the most productive component you can install to get the most power from your stock car is the CAI. From there, most people move on to installing the Catback exhaust. Dont buy a complete longtube exhaust system with custom piping, no cats, and cutout expecting to see maximum gains when you havent touched the intake system yet. You always want to try and balance out the intake and exhaust system so that you have an equally balanced motor, otherwise you are leaving power out on the table. First few power mods should be a complete intake system and complete exhaust system(CAI, MAF Ends, Airfoil or TB, Header, Y-pipe, Catback or Cutout). Once you have accomplished this, then you have a good solid base from which to build a stout, internally modified motor. Basically, being able to get the air into and outta the motor as fast as possible will create the most power. If you plan on roadracing, the best thing you can do to increase the performance of your car is to add a nice suspension setup for it. Just like in the quartermile, large amounts of power in a car without suspension is useless, but even moreso on a roadcourse. Putting the power to the ground is just as important as making power. Generally speaking, to increase straight line performance, LCA's are most effective while PHR's, Sway Bars, and SFC's are most effective in eliminating body roll and flexing. Spring and Shock kits are most effective in eliminating bounce, weight transfer, body roll, dive in braking, etc.
                        - Further discussion of this post can be found here.
                        - Special thanks to Aaron (Gangly) for this writeup
                        Old Mar 30, 2005 | 12:04 AM
                        Vendetta's Avatar
                        Default Compression Ratio
                        COMPRESSION RATIO
                        Compression ratio is a term that all of us are familiar with, but very few of us really understand. Whether we are milling down stock heads, swapping for some aftermarket ones, changing the stroke, the pistons or just simply using a thinner head gasket, changes to you engine combo have a profound affect your compression ratio and, consequently, on overall performance and drivability. With that in mind, I developed and easy to use formula to calculate compression ratio.
                        Compression ratio is defined as "the volume of the cylinder at BDC (bottom dead center) divided by the volume of the cylinder at TDC (top dead center).
                        CR = (Vbdc/Vtdc)
                        Without getting into too much detail, we can expand this to the following equation:
                        CR = [{(B/2)^2 * S*Pi}+Vcc+Vp+{(B/2)^2*Pi*(DH+TG)}]
                        [{(B/2)^2*Pi*(DH+TG)}+Vcc+Vp]
                        Where:
                        CR= Compression Ratio
                        B = Cylinder bore (Stock LT1 = 4.00in)
                        S = Stroke (Stock LT1 = 3.48in)
                        Vcc= Combustion Chamber Volume (Stock LT1 = 58cc = 3.539 in3)
                        Vp= Piston Volume (Stock LT1 = 4.5cc = 0.274606 in3)
                        DH = Deck Height (Stock LT1 = 0.015 in)
                        TG = Head Gasket Crush Thickness (Stock LT1 = 0.05 in)
                        Pi = 3.1415
                        As long as all other variables remain constant, you can change a single variable (for example larger/smaller combustion chamber size) to determine your new Compression Ratio.
                        *Convert Cubic Cenimeters (ccs) to Cubic Inches (in^3) using the following formula
                        in^3 = (CCs/16.387064)
                        Big thanks to Jeff (Metalbeast) for submitting this formula
                        To discuss this formula and/or post your results, go here.
                        Old Mar 30, 2005 | 12:30 AM
                        Vendetta's Avatar
                        COMMON ACRONYMS
                        Modified For LT1 Owners
                        ! - using this before an acronym means removal of that item from the vehicle (example: !EGR)
                        1/4 - Quarter Mile (drag racing)
                        1LE - Suspension Handling Package Option
                        2WD - Two Wheel Drive
                        4L60E - actual part name for the Automatic 4-speed transmission
                        4WD - Four Wheel Drive
                        700R4 - older generation 4-speed GM automatic transmission
                        A3 - 3-speed automatic transmission
                        A4 - 4-speed automatic transmission
                        A/F - Air Fuel Ratio
                        AIR - Air Injection Recirculation (part of emissions system.)
                        APHR - Adjustable Panhard Rod (Suspension)
                        AFR - Air Flow Research (Vendor)
                        ASP - Automotive Specialties Performance (Vendor)
                        ASR - Camaro version of traction control
                        ATF - Automatic Transmission Fluid
                        ATI - Supercharger Company (Vendor)
                        AWD - All Wheel Drive
                        B4C - Police Package Option
                        BBC - Big Block Chevy engine
                        BBDC - Before Bottom Dead Center
                        BDC - Bottom Dead Center
                        BHP - Brake Horsepower
                        BOV - Blow Off Valve (turbo related)
                        B/O - Bolt-On Modifications
                        BSM - Body Side Moulding - door ding guards on your doors.
                        BTDC - Before Top Dead Center
                        BTW - By The Way
                        C4 - Fourth Generation Corvette (1992-1996)
                        CAGS - Computer Assisted Gear Selection (the "skip-shift" on M6 cars.)
                        CATS - Catalytic Converters (emissions/exhaust system)
                        CAI - Cold Air Induction
                        CI - Cubic Inches (engine displacement)
                        CKP - Crankshaft Position (sensor)
                        CMP - Camshaft Position (sensor)
                        CONV/'vert - Convertible
                        CR - Compression Ratio
                        DEG - Degrees (timing or temperature)
                        DRL - Daytime Running Lights
                        DR's - Drag Radial Tires
                        DSL - Driveshaft Safety Loop
                        DTC - Diagnostic Trouble Code
                        ECM - Engine Control Module
                        ECL - Exhaust Lobe Center Line (camshaft)
                        ECT - Engine Coolant Temperature (sensor)
                        EGR - Exhaust Gas Recirculation (emissions system)
                        EGT - Exhaust Gas Temperature
                        E/T - Elapsed Time (drag racing time measurement)
                        FAST - Fuel Air Spark Technology (Vendor)
                        FBODY - GM chassis designation for Camaro/Firebird
                        FI - Forced Induction (turbos, superchargers)
                        FIPK - Fuel Injection Performance Kit (See K&N)
                        FMIC - Front Mounted Intercooler (turbo)
                        FMS - Futral Motorsports (Vendor)
                        FMU - Fuel Management Unit
                        FPR - Fuel Pressure Regulator
                        FPSS - Fuel Pressure Safety Switch
                        FRA - "Free Ram Air" modification
                        FRC - Fuel Rail Covers
                        FLP - Finish Line Performance (Vendor)
                        FTRA - Fast Toys Ram Air (product)
                        FWD - Front Wheel Drive
                        FWIW - For What Its Worth
                        GMMG - Vendor known for producing modified GM backed F-bodies
                        H/C - Heads and Camshaft
                        HO2S - Heated Oxygen Sensor
                        HP - Horsepower
                        HPE - Horsepower Engineering (Vendor)
                        HPP3 - Hypertech Power Programmer 3 (product)
                        IAC - Idle Air Control (solenoid)
                        IAT - Intake Air Temperature (sensor)
                        IC - Ignition Control Circuit
                        ICL - Intake Lobe Center Line (camshaft)
                        IGN - Ignition
                        IMHO - In My Humble Opinion
                        IRS - Independent Rear Suspension
                        K&N - Brand name of air filter
                        KR - Knock Retard (tuning)
                        LCA - Lower Control Arm (suspension)
                        LGM - Lou Gigliotti Motorsports (Vendor)
                        LM - Loud Mouth (exhaust system by SLP)
                        LMAO - Laughing My *** Off
                        LOL - Laughing Out Loud
                        LPE - Lingenfelter Performance Engineering (Vendor)
                        LT1 - Generation 2 GM smallblock V8 engine (introduced 1992)
                        LT4 - Generation 2 GM smallblock V8 engine (introduced 1996)
                        LT5 - GM/Lotus/Mercury Marine joint collaboration project, DOHC 5.7L V8 engine found in the Corvette ZR-1 (introduced 1990)
                        LSA - Lobe Seperation Angle (camshaft)
                        LSS - Lou's Short Stick (shifter handle)
                        LT - Long Tube Headers
                        LTFT - Long Term Fuel Trim (tuning)
                        LTRIM - Long Term Fuel Trim (tuning)
                        M6 - 6-speed transmission
                        MAF - Mass Air Flow sensor (measures amount of air entering intake)
                        MAP - Manifold Absolute Pressure (sensor)
                        MAFT - Mass Air Flow Translator (product)
                        MN6 - Option code for factory 6-speed transimission.
                        MTI - Motorsport Technologies, Inc. (Vendor)
                        N/A - Naturally Aspirated (all-motor)
                        N20 - Nitrous Oxide
                        NBM - Navy Blue Metallic (color)
                        NOS - Nitrous Oxide Systems (brand name)
                        NWS - Not Work Safe (do not click link if you are at work, unsuitable material inside)
                        O2 - Oxygen Sensor
                        ORY - Off Road Y-pipe
                        ORP - Off Road Pipe
                        PCM - Powertrain Control Module (your vehicles engine/tranny computer)
                        PCV - Positive Crankcase Ventilation (emissions system)
                        PE - Power Enrichment (tuning)
                        PHR - Panhard Rod (suspension)
                        PITA - Pain In The ***
                        POS - Piece Of ****
                        P/P - Ported And Polished
                        QTEC - Quick Time Electric Cutout (product)
                        QTP - Quick Time Performance (Vendor)
                        ROFLMAO - Rolling On Floor Laughing My *** Off
                        RPM - Revolutions Per Minute (engine speed)
                        RWD - Rear Wheel Drive
                        RWHP - Rear Wheel Horsepower
                        RWTQ - Rear Wheel Torque
                        SAE - Society of Automotive Engineers
                        SBC - Small Block Chevy engine
                        SC - Super Charger
                        SES - Service Engine Soon lamp (on dash)
                        SFC - Subframe Connectors
                        SLP - Street Legal Performance (Vendor)
                        SOM - Sunset Orange Metallic (color)
                        SOTP - Seat Of The Pants
                        SS - Super Sport
                        SSRA - Super Sucker Ram Air
                        STB - Strut Tower Brace
                        STFT - Short Term Fuel Trim (tuning)
                        STRIM - Short Term Fuel Trim (tuning)
                        T56 - actual part name for the M6 transmission
                        TA - Trans Am
                        TB - Throttle Body
                        TBODY - Throttle Body
                        TBRAKE - Transmission Brake
                        TEA - Total Engine Airflow (Vendor)
                        TC - Torque Converter
                        TCS - Firebird version of traction control
                        TDC - Top Dead Center
                        TFP - Transmission Fluid Pressure (switch/valve)
                        TH350 - Turbo Hydromatic 3-speed automatic transmission
                        TH400 - Heavy Duty Turbo Hydromatic 3-speed automatic transmission
                        TNT - Texas Nitrous Technologies (Vendor)
                        TP - Throttle Position
                        TPiS - Tuned Port Induction Specialties (Vendor)
                        TPS - Throttle Postion Sensor
                        TQ - Torque
                        TR - Thunder Racing (Vendor)
                        TSP - Texas Speed & Performance (Vendor)
                        TT - Twin Turbo
                        TT2 - Torque Thrust 2 (type of wheels by American Racing)
                        TTOP - T-Top roof
                        TTT - "To The Top"
                        UCA - Upper Control Arm (front suspension)
                        VATS - Vehicle Anti-Theft System (the coded chip in your ignition key)
                        VERT - Convertible
                        VSS - Vehicle Speed Sensor
                        WB O2 - Wide Band Oxygen Sensor
                        WOT - Wide Open Throttle
                        WS6 - Firebird Performance "Ram Air" Package (RPO code)
                        WTB - Want To Buy
                        WTF - What The ****?
                        WTT - Want To Trade
                        WU8 - Camaro Performance SS Package (RPO code)
                        Y2Y - Exhaust Upgrade Option Code for SS Camaro (Dual-Dual system)
                        YBODY - GM chassis designation for Corvette
                        Z28 - Camaro equipped with V8 engine (RPO code)
                        ZR1 - Corvette with LT5 motor, GM and Lotus joint project in the early 90s
                        Old Mar 30, 2005 | 04:32 PM
                        Vendetta's Avatar
                        Default Multimedia
                        MULTIMEDIA
                        I was just tooling along one day on my PC, and I thought "I feel like checking out some nice looking LT1s". I headed over to camaroz28.com, but quickly realized that they don't have a multimedia section. I then went over to LT1tech.com and noticed that they didn't have one either. I wasn't about to go over to Cardomain and check out some of the LT1s there, since the majority of them are not only V6s, but ugly V6s. I figured I'd start a thread on here to begin a gathering of some pictures and videos of LT1s since the multimedia section on this site is primarily LS1-based.
                        Looking for a place to post some pictures of videos of your LT1? Post them right here.
                        Old Mar 30, 2005 | 04:40 PM
                        Vendetta's Avatar
                        FAVORITE MODS
                        For a discussion of our various members' favorite modifications, check out this thread. This should be a great help for you newer LT1 enthusiasts who are unsure of where to start.
                        Old Mar 30, 2005 | 04:45 PM
                        Vendetta's Avatar
                        NEWBIE MISTAKES
                        Let's face it- even the best of us have made some stupid newbie mistakes. Flowmaster catbacks. Edelbrock TES midlengths. HPP3.
                        Those of us who have been down the road of stupid-newbieness have a responsibility to make sure you new guys don't make the same mistakes. So, we've constructed a thread here to help you noobs out and save you guys some money.
                        Old Apr 10, 2005 | 01:07 PM
                        Vendetta's Avatar
                        DYNO ARCHIVE
                        If you're still new to the LT1 scene and are looking to feel your way around how much power and what kind of times people are running with certain modifcations, you should check out the link below. There is a growing archive of dyno results and track times in the thread linked that will help you out and give you a general idea of the results people are getting with certain mods.
                        To check out the LT1 Dyno/Track archive, click here.
                        Thanks to Chris (97M6Formula) for the LT1 Dyno Archive
                        Old May 26, 2005 | 04:00 PM
                        Vendetta's Avatar
                        AUTOMATIC VS MANUAL
                        The 4L60/E vs T-56 argument will be continued on for eternity. Which is better? Neither. Each have their own strengths, and their own weaknesses. Click the link below for our discussion.
                        To check out the Automatic vs Manual Transmission argument, click here.
                        Old May 26, 2005 | 04:07 PM
                        Vendetta's Avatar
                        Engine Removal
                        For more information on removing the LT1 from your fourth generation F-body, check out these links.
                        To check out the top vs bottom engine removal discussion, click here.
                        Old Jun 20, 2005 | 06:08 PM
                        Vendetta's Avatar
                        Best Sounding Catback
                        While some catbacks clearly perform better than others, the issue of which sounds the best has been debated since the LT1 engine debuted in 1992. Today, we've got a large variety of aftermarket manufacturers selling a ton of different styles of catback exhaust. From the hardcore legions of Loudmouth fans to the 2OTL users who love a mellow tone, everybody has an opinion. Click the link below for a discussion on 9 of the most popular catbacks.
                        To view the thread, click here.
                        Old Jun 20, 2005 | 06:16 PM
                        Vendetta's Avatar
                        Part Number Catalog
                        Ever had a problem finding a part number? Thanks to ACW, most of the numbers to the parts in our car are now conveniently sorted and categorized in one thread in the Newbie section.
                        To check out ACW's list of 1993-2002 F-Body parts, click here.
