Pinion angle vs. traction?
Last week at the strip I was blowing the tires off on almost every pass unless I preloaded the car on the converter. Anyway I was checking over the suspension last night and saw my pinion angle was set at +1* after my S60 install.
What effect if any does the pinion angle have on traction at all? Does it help drive the tires down at all?
LS1Tech Premium Sponsor
http://www.bmrtvonline.com/video_detail.php?mId=3788
Hello, you need to get your pinion angle correct. The main purpose of pinion angle is to get your driveline angle correct to avoid binding and vibration issues. Here is a link to our video on the correct way to set the angle. If you have any questions polease give me a call.
Moderator
The pinion angle is secondary, the real traction
deal is the torque arm angle (with LCA angle,
it sets the instant center). You need to adjust
this at the nose of the TA, not at the pumpkin.
The pumpkin pinion angle adjustment is just to
get driveline angles matched.
If all you do is crank on the adjuster you'll be
spinning your wheels. Heh.
Well, I have the spohn tunnel mount TA and UMI lcas with the relo bracket. What should the IC be and how do you figure it from the 2 angles?
I currently have no adjustment in the nose if the TA and my lca are on the lowest hole in the rear. My car is lower in the front some with QA1's but the rear is SLP level 2 spring and QA1 rear shock.
The only way that you can adjust your instant center is with the rear of the lower control arms. Instant center is the intersect point where the lower control arms centerline and torque arm centerline would intersect. If your car hooks good then unloads the tires after you get 30 or 40 feet out move your control arms up a hole.
Thanks.
