Old 05-13-2016, 02:45 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Chevoret Camaro or Pontiac Firebird Brake Guides
Browse all: Brake Guides
Print Wikipost
CTS-V Brake Install w/ Pics
Old 11-23-2010, 02:57 PM
  #281
dagersh's Avatar
Originally Posted by Fbodyfan
Would the pin kit 89047711 be the same one to use with the six piston calipers?
Just bumping this for an answer...
Also, what is a pin kit?
Thanks!
Michael G
Old 11-24-2010, 03:31 AM
  #282
Fbodyfan's Avatar
Brembo pads are replaced through an opening in the back of the caliper. The pads are then secured using a rectangular spring plate and two drift pins. Evidently the CTS-V calipers do not come with the pins and spring. They have to be purchased separately.
Old 11-24-2010, 12:19 PM
  #283
dagersh's Avatar
Thanks Fan!
Old 12-20-2010, 09:54 AM
  #284
Evan G's Avatar
Default Brake brands
Hey those Brakes look sweet with those vette rims! I was wondering what other brands can I Buy other than brembo, that wont hurt my wallet?
Old 12-20-2010, 04:53 PM
  #285
Wesmanw02's Avatar
There really is not much else thats affordable, what makes the Brembo calipers attainable and affordable is that they are a factory part.
Kits such as Stoptech, Baer, and Wilwood are typically between $2,000 and $3,000 for our cars, or any car for that matter.
Old 12-27-2010, 07:58 PM
  #286
cookba's Avatar
has there been any progress on getting something on a MWC 9" yet?
Old 01-08-2011, 07:18 AM
  #287
SS Brandon's Avatar
! ! ! ! SOLD ! ! ! !
Anyone interested, I have this same setup for sale - Brand New & ready to go!
See the thread here:
https://ls1tech.com/forums/parts-cla...-must-see.html
!!!!! SOLD !!!!!
Old 01-22-2011, 12:01 PM
  #288
1badWS6's Avatar
Has anyone done this with a set of WS6 rims? If so, did you need spacers?
Old 01-22-2011, 04:21 PM
  #289
69TA's Avatar
yes you would need spacers.
the CTSV calipers stick out like a ****
Old 01-23-2011, 03:58 PM
  #290
1badWS6's Avatar
Word thanks.
Old 01-23-2011, 04:36 PM
  #291
qwikz28's Avatar
Word thanks.
Unless you fabricate a custom bracket, they aren't fitting under the WS6 wheels anyway; spacer or not.
Old 01-30-2011, 06:19 PM
  #292
skorpion317's Avatar
I read through this whole thread, and I'm still a little confused about what exactly is needed. I get that you need the calipers, hardware, rotors, etc. I'm not sure if brackets are needed or not. Will these calipers clear my wheels (19x9.5 HP Evos, I think they have a 38mm offset)? Are there 2-piston Brembo calipers available for the rear brakes?
Old 01-30-2011, 08:41 PM
  #293
qwikz28's Avatar
For the first question, it would be close, but I would guess no. I had the HP HPR5s in the same size, which are very similar, but with the 3" lip, the face of the wheel sits in very far. I would get the ruler out and see how much clearance you have from the stock brakes to the Evos, and post that up to find out though.
For the second question, yes, but I don't believe they simply bolt right in. Likely won't be a very economical choice.
Old 01-30-2011, 10:21 PM
  #294
Are any brackets needed to install the 4-piston CTS-V Brembos? Or do they bolt right on?
Old 01-30-2011, 11:50 PM
  #295
peterlawl84's Avatar
The CTS-v brembos bolt on with a couple of washers to center the caliper over the rotor. You might need a spacer, depending on the wheel design.
The 6-piston c6z06 PBR rotors require brackets.
Old 01-31-2011, 01:32 PM
  #296
qwikz28's Avatar
The 6-piston c6z06 PBR calipers require brackets.
FTFY
Old 02-01-2011, 03:13 PM
  #297
thanks for the correction.
Old 02-01-2011, 06:09 PM
  #298
Last question - are there any aftermarket 14" blank rotors available? I'm looking for maximum braking power, not a bling-bling cros-drilled/slotted rotor setup.
Old 02-02-2011, 05:33 AM
  #299
Fbodyfan's Avatar
I believe that EBC has their entry level blank for the ZO6, and I saw a centric blank listed on Rockauto, but centric's website does not show it so I am not sure if it exists.
DBA and powerslot/cryoslot have slotted rotors that are not drilled. That is what I am planning on using when I do mine.
Old 02-02-2011, 07:25 AM
  #300
After doing some digging, DBA has 14" blanks for the Z06 listed on their website. I haven't been able to find a retailer that sells them though, it seems everyone only has cross-drilled or slotted versions of the rotor.
Quick Reply: CTS-V Brake Install w/ Pics
