Hotchkis Springs
Hotchkis Springs
I recently installed Hotchkis Lowering Springs on my 2002 SS. The car rides on 275/40 ZR17 BFG KD's.
Measuring from the garage floor through the center of the wheel to the fender lip I get the following results:
Front - 27 Inches
Rear - 26 1/2 Inches
To me this makes the car look like it's got a rake towards the rear. Is this normal for these springs? Could anybody get me some measurements on their Hotchkis equipped LS1 F-body?
Cheers
Front - 27 Inches
Cheers
I'm using the stock Isolators, and I have a couple of hundered miles on since the install. From the links you posted 99Bluz28, it looks as if a few others have had this issue, some like the look and some don't.
HoLLo, your car sits exactly how I hoped mine would, nice even fender gaps.
I guess I have to either make a spacer for above the Isolator, or try my stock springs with the Hose Mod and see what looks better.
Thanks for the responses, much appreciated.
LS1TECH Sponsor
It depends on *how* they are wound. Not all progressive springs are the same. Hotchkis are progressive, they gain rate start to finish. Mine as dual-stage. One soft rate as a tender (locating) spring, and the actual working rate that is the only one in play when driving so the are actively linear rate. Most are meant to be this way, but if the "soft" end isn't done right is can come into play while driving making the spring act more progressive then linear.
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
