LS Swap Parts List: Every Part You NEED for Your First Swap
LS swaps are time-consuming and wallet-draining. But at the end of the day, they’re relatively simple. Here’s a universal LS swap parts list to help get you started on your first swap! (LS3 Roadmaster Wagon Project | Bonus)
LS swaps come in all shapes and sizes and budgets. Some are world-class custom builds, while others throw together hand-me-down parts and junkyard engines. But no matter your skill level or budget, it can be extremely daunting to take that initial step toward actually doing your first swap. If that’s you, welcome to the club. I was you about a year and a half ago. Researching. Dreaming. Collecting parts. About to turn more wrenches than I’d ever turned.
Make sure LS1Tech’s LS3 Roadmaster Wagon Project HERE in our forum
We’re rolling out a large chunk of videos and articles all this week!
Now that I’m on the other side of the process — well, as much as one can call a home-build project car “finished” — I wanted to put together a couple of universal guides to help folks get ready for a first swap.
Please note that you’ll still have to research specific parts for your specific application. And that this will take a lot of time. And that this list doesn’t represent everything you’ll need in terms of tools, accessories, and performance upgrades like suspension and brakes. Fortunately, there are forums like LS1Tech.com where friendly people can help out with tips and offer counsel when things go wrong. Please also note that many of these items are going to seem obvious. But that’s kinda the point.
LS swaps are frustrating at times. And expensive. But they are also relatively simple. Especially when you’re using a Chevrolet Performance Connect & Cruise system.
Universal LS Swap Parts List | Parts We UsedÂ
- Engine | Parts 1-5 all included with LS3 E-ROD Connect & Cruise system from Guaranty Chevrolet
- Transmission
- Engine Computer
- Transmission Computer (unless you’re using an older style transmission)
- Wiring Harness
- LS Swap Oil Pan & Gasket | Holley 302-2 & OEM LS3 gasket
- LS starter | GM 19418895
- Engine Accessories & Belt | Holley Premium Mid Mount Accessory Drive System 20-180 BLK
- Motor Mounts & Transmission Crossmember | BRP Hotrods 91-93 B-Body LS Swap Kit
- Driveshaft | local shop resized my OEM driveshaft
- Limited slip differential | Eaton TrueTrac 913A481
- Fuel system capable of 60 PSI constant | Earl’s Vapor Guard Hose & AN Fittings (Holley)
- Fuel filter/regulator | AC Delco GF822
- Accelerator pedal (if drive by wire) | CTS-V style pedal (included with LS3 E-ROD crate motor)
- Air intake | Chevrolet Performance 19301246
- Mas Air Flow sensor | Included with LS3 E-ROD crate motor
- Quality radiator, fan, & cooling system | Champion Cooling 1517 & OEM Impala SS fans
- Digital gauges or analog gauge adapters | Dakota Digital VHX 1023
- Headers & cats (if required in your state) | 5th Gen Camaro (included with LS3 E-ROD crate motor)
- Killer exhaust | Magnaflow xMod mufflers, 2.5″ Universal Builder Kit, flex joints, & Helmholtz chambers
LS3 Roadmaster Wagon Project EPISODES
Part 1
Parts & Project GoalsPart 2
Michelin Tires, American Racing Wheels, Eaton TrueTrac, & Sway BarsPart 3
Wilwood D52 Disc BrakesPart 4
Coilovers & Control ArmsPart 5
Goodbye TBI, Hellow Earl’s Vaporguard Fuel SystemRacingJunk.com Bonus
Everything You Need to START a Chevy Performance Connect & Cruise System
(LS and LT Engines)Part 6
Installing an LS3 E-ROD & Holley Accessories in a Roadmaster Wagon!!!Part 7
This Magnaflow xMod Exhaust Made My LS3-Swapped Wagon Sound INSANE!Part 8
Dakota Digital: LS Swap Gauges & Wiring Made Easy! (Plus Guaranty Chevy & Chemical Guys!)Part 9
LS Swaps Are a LOT More Expensive Than You Think!!!Part 10
10 Tips for Surviving Your First LS SwapBonus
Every Part You NEED For Your First LS Swap
PARTNERS
- Guaranty Chevrolet: https://www.occhevy.com/
- Holley: https://www.holley.com/
- Magnaflow: https://www.magnaflow.com/
- Chemical Guys: https://www.chemicalguys.com/
- Dakota Digital: https://www.dakotadigital.com/
- Michelin: https://www.michelin.com/
- Wilwood Brakes: https://www.wilwood.com/
- Eaton: https://www.eaton.com/
- Sony: https://electronics.sony.com/
DISCOUNTS PROVIDED
- Summit Racing: https://www.summitracing.com/
- Muscle Rods aka BRP HotRods: http://www.brphotrods.com/
- Sikky Manufacturing: https://www.sikky.com/
- American Racing Wheels: https://www.americanracing.com/
