Total Sleeper! Junkyard LS-swapped Chevy Colorado Meets 22 PSI of Boost
By -
ls1tech.com LS-swapped V8 Chevy Colorado nitrous turbo build
This Colorado is the epitome of an unsuspecting, sleeper truck.
Talk about a sleeper: no one would suspect what is under the hood of this Chevy Colorado. This particular truck is a “fleet-spec” model: white with unpainted bumpers and trim, and steel wheels. It couldn’t look any more pedestrian in appearance.
Pop the hood, and you’ll see a very a tired, looking junkyard 5.3L LS V8 where a four cylinder once resided. That junkyard LS is boosted thanks to a Borg Warner S480 turbocharger. But wait, there’s more: follow those hard lines in the engine bay and you’ll see a nitrous setup plumbed into the intake. Here is an ultra-budget, LS-swapped Colorado. Perfect.
LS1tech.com forum member, and YouTube personality Sloppy Mechanics has cobbled this swap together and it’s time to see what it will do on the rollers. 4 (5?) psi of boost sees this old, unopened 5.3 putting down 462whp. We are guessing that’s just wastegate pressure, and that’s why it was the baseline run. 462whp is good, but how does that do when paired up to a 50 shot of nitrous oxide? With a small jet and just a base tune: 550whp. Now things are getting good, but Matt says the two magic words synonymous with big power runs on a dyno: “fuck it!” My man.
After playing with the boost controller for a bit, Matt comes up with a 22psi target. Without nitrous, it makes 820whp right off the bat. Matt and his dad talk fueling: the car has enough injector for more power (“they’re only at 50% duty cycle), but the boost controller doesn’t want to give more than 22 pounds. If you’re out of boost, and you have more fuel, time to get more air via a big helping of nitrous. They heat up the bottle(s?), and get both kits ready. With two jets in the intake, and 22psi of boost, this LS-swapped Colorado puts down a massive 1076RWHP and 1050WTQ. Holy hell. Good job, Matt!
Jake Stumph is a lifelong car enthusiast and racer, and former content editor for Internet Brands Automotive which he joined in 2015. His work has been featured by several other prominent automotive outlets, including Jalopnik and Autobytel.
He obtained a bachelor's degree in Political Science at the Ohio State University in 2013, then pivoted from covering politics and policy to writing about his automotive adventures, something that, he says, is a lot more fun. Since that time, he has established connections with most of the world's major automakers, as well as other key brands in the automotive industry.
He enjoys track days, drifting, and autocross, at least, when his cars are running right, which is uncommon.
