LS2-Powered S10 Shatters a Transmission on the Dyno
Bell housing of the LS2-powered S10 failed, leading the owner to wonder if the engine might be damaged.
LS1Tech member “Elkwagon” has a sweet Chevy S10 pickup that has been fitted with a built LS2. He recently took that powerful little pickup to the dyno to see what kind of power it was making at the wheels and everything looked good at first, with nearly 400 wheel horsepower. However, during that pull, the front universal joint failed, allowing the driveshaft to wail away on the underside of the truck, but worst of all, the sudden vibration caused the bell housing to fracture along the top-line where it bolts to the block.
After seeing the damage to the transmission and before getting a chance to examine the built LS2, the OP posted to the forum, asking the community whether or not they think that the engine might be damaged as well. Fortunately, this thread has a happy ending.
LS2 S10 Introduction
When the OP first shared his dyno day carnage with the forum, he proved the picture below, showing the broken bell housing of his LS2-powered Chevy S10 pickup. He also explained exactly what happened.
Long story short I have been working on my first LS swap for a few months now, and finally finished it. 6.0 with H/C/I, long tube headers, 4l80, Quick Performance disc 9″ all stuffed in a 91 S10. Truck sounds amazing, but on the first pull the front U-joint came apart and carnage insued. Driveshaft did damage to various things, but worst of all when it unloaded the trans it completely broke the bell housing from the block. My question is did this cause damage to the engine? As in force the crank forward??? Is there a way to check for this? I have lifted the body from the chassis, just as I did for the install, so access would be easy.”
He would go later provide a bit more additional information on the failure.
“5K ish. Was on a nice pull, curve looked great and was pushing 400 already.
The Community Responds
The first person to offer insight on the health of the LS2 engine was “Ls7Colorado”.
Doubt it hurt the engine, I would be more worried about the front pump in the transmission
“Che70velle” agreed that the engine was likely fine.
Kinda doubt it hurt the engine. Only way to know without a tear down is simply start the engine and observe/listen. Can you support the engine under the oil pan, and do a startup with tranny off?
While “kott0n” asked more about the mounting situation in the S10.
Is the motor and trans solid mounted? Or is one solid mounted and the other isn’t?
What a bummer. Hopefully you get up and running soon.
To which the OP replied with the following.
Both on standard rubber mounts actually. Should be on the road this weekend!
The Engine is Good
The OP posted about the transmission failure on August 8 and on August 20, he posted some good news.
It’s alive! Buttoned everything up and took it for a drive last night. Traction is non existent in first gear anywhere, second is marginal…..I have never driven anything that is a bigger handful when spinning, the short wheelbase is sketchy!!
Hoosier DR2’s going on it Thursday, and hitting the track Friday God willing!!!!
He would follow that post up with information on a more successful dyno run.
Hit the Dyno last night, with the TH400 and a loose 3800 converter it made 424whp and 485ftlbs with a nice flat curve. I was happy enough, tuner mentioned with a lockup converter it would have been as much as 50hp more, and its common knowledge that this Dyno reads lower that most. He has had vehicles that had been done on other Dyno’s that showed 80whp more than this one. Tonight we race!
Unfortunately, there is no update on track times, but it is clear that the dramatic transmission failure didn’t damage the OP’s built LS2.
Join the LS1Tech forums now!
