Your LT1 Dream Swap is Running and Waiting on a Pallet
By -
Buying a crate motor is a great way to get a complete engine for your swap. Unfortunately the motor will still need a lot of parts to get running, but this LT1 swap won’t.
Motor swapping a car is a labor intensive job, even if you are just swapping in the same kind of motor you had in the car before. The shear mass of parts, connections, and wiring can be overwhelming. As anyone who has done a swap can tell you, you will need additional parts to finish your swap. Unless the swap was fresh, you will need hoses, seals, and a variety of bits that we all forget until half-way through. For a lot of people buying a crate engine is the best option. The motor comes complete and ready to run. Unfortunately it will not come with any additional parts to make in run in your application. Buying a LS1 for a FD Mazda RX7 swap will not get you the gas pedal or the transmission. So, why doesn’t anyone sell a complete package, like a running, driving LT1 swap?
ALSO SEE:Weapon X’s C7 Makes 1,000 Horsepower From a Hopped Up LT1
Good news! Cleveland Power and Performance has a solution for you. As you can see in the video they have palletized a complete LT1 drivetrain which is completely ready to run. In fact, as you will see it actually runs on the pallet. The fuel tank, wiring, ecu, cluster, and pedals are setup to run. You can buy this drivetrain and know for sure your new motor swap will run.
chevelle lt1 swap
Imagine what kind of cool projects you could put this setup in and the amazing performance it offers. The pallet set up comes complete with the 8-speed automatic transmission. We can only hope someone picks this up and throws it into something cool. The value is pretty good too, as a LT1 crate motor would cost you $11,000. So, at $13,495 you get a lot of other parts for the additional $2,500 over a crate engine. Let us know what you think in the comments.
