Can I get 11 second tag with an 1/8th mile pass?
So I know the conversion shows I should be an 11.6 car, I live 2 miles from Irwindale speedway and it is only an 1/8 mile track, best et so far is 7.49 at 92 mph.
Mods 228r cam, 241's milled .042, fast 36lb injectors, ebay stainless steel headers, tsp ory, tsp rumble with magnaflow muffler, upgraded timing chain (im too lazy to get up and look in my box of parts as to which one but it is from tsp) ls6 ported and shimmed oil pump, still on the ls1 intake. Ohh I have a cutom 3k stall built trans and 3:42 gears.
My question is even though I don't have a full 1/4 mile pass, can I still apply for the 11 second club?
Very true I have yet to run it at a track but I know p top it does not lay down, got a mach 1 with race suspension on a 125 shot to prove that. Had it by easily 1.5 cars and thats letting off about 100-200 feet from the finish.
I know what you are saying but this thing will pull hard through the end, just curious if not that is fine with me, but there are not that many 1/4 mile tracks that are good around southern cali.
What are you 60fts? Have you thought about maybe going with a bigger stall? I am still running stock lca's, shocks, rear sway bar, and torque arm. My only suspension mods are qa1 coilovers w/ 300lb springs, boxed sfc and tubular non adj panhard bar.
Fontana isnt all that bad. You usually are a few tenths off of what you could be at Famoso no more than that though. You should still be able to get a solid pass there. When I ran my 11.2 pass at Fontana the DA was around 900.
