What type of composite are the LS series intakes?
and if its made of titanium and nylon...would that make it made of Tylenol? lol
http://www.allbusiness.com/automotiv...8202092-1.html
Zytel was also used for oil pans in the C-class, PT cruiser uses it in an intake manifold, exhaust mounts on some VWs, and the company Valeo makes headlights using Zytel in the VW Passat and Citroen C4.
Gen-3 LS1/6
The LS1 and LS6 manifolds were produced using a 'lost core' plastic-molding process that produced a single-piece manifold." The lost-core process involves the use of a low-melting-temperature metal core, which is loaded into a plastic-molding tool, over-molded, and then melted out after the part is formed. Nylon 66 was the material used to produce the LS1 and LS6 manifolds.
Gen-4 LS2/3/7
The LS2 and LS7 manifolds utilize a more traditional plastic-injected-molding process that produces three different intake-manifold sections, which are then fitted together and vibration welded around the edges.
Vibration welding, sometimes referred to as "sonic welding," involves melting the composite together after vibrating the materials to produce enough friction for a weld. Although the new manifold material looks similar to that used in an LS1 or LS6 unit, it's actually Nylon 6, a glass-filled polymer that is better suited to the vibration-welding process.
but anyway the interesting part was one of the two additives in dexcool that give it it's long-life properties was 2-eha, which is also characterized as a plasticizer and is incompatible with nylon, or various nylon materials and compounds. If you research the dexcool problems the intake gaskets that had those failures were made or comprised of nylon, and GM issued either a TSB or at least reference to a new updated gasket material as the fix. For the LS series of engines (having intakes made of nylon) it's probably a good thing no coolant runs through them.
BOSS APPROVED!
