mixing leaded fuel/ leaded fuel killing o2 / and meth questions
When you mix leaded fuel lets take VP C12 and mixes with pump 93 50/50 is it a clean mix down the middle?
Why does leaded gas kill the o2 ? how long does it take? What do they do when they start to go out ?
My buddy has a car that was built and tuned in middle US on E85 fuel.
Can he mix 80%meth / 20 % gas. To make something like E85 here where we don't have it ? Most likely will need retuning just thinkng ?
I thought the leaded gas was just bad for the cats.
E85 requires retuning and its not always easy to get. In California I think there is one place that sells to the public.
Catalyst poisoning occurs when the catalytic converter is exposed to exhaust containing substances that coat the working surfaces, encapsulating the catalyst so that it cannot contact and treat the exhaust. The most notable contaminant is lead, so vehicles equipped with catalytic converters can only be run on unleaded gasoline.
Gotta love Wikipedia
Leaded gasoline contaminates the oxygen sensors and catalytic converters. Most oxygen sensors are rated for some service life in the presence of leaded gasoline but sensor life will be shortened to as little as 15,000 miles depending on the lead concentration. Lead-damaged sensors typically have their tips discolored light rusty.
yes the leaded gas will kill your 02 sensors and your cats no telling how fast it will cover the surfaces but in time it will kill them
high HCs (unburned fuel) will also kill them
ive also seen 02s not killed but not working anymore because of an exhaust running too cold, this was on an eclipse i worked on, the kid had straight pipe exhauts with no cat and norestriction whatsoever and the area around the cat only ever got up to around 350 degrees. i pulled the 02s out and they were black, cleaned them with a torch welded in a cat and off he went car is running fine now
