What if you designed a striaght 8 LSX???
Would a straight 8 LS Series engine outperform a V8 LS Series engine?
Also don't argue about disadvantage of length and weight.
wiki has a lot of decent info on inlines from I-4 on up, the info under the I-5 is probably the most revealing.
would a straight 8 outperform a v-8 disregarding weight and packaging, I think so based on having a common exhaust manifold for all 8 cylinders so you can take more advantage of exhaust tuning. You also get even firing pulses per revolution opposed to uneven firing pulses of a 90 deg V-8.
I don't think a straight 8 would have less torsional vibration than a v-8, it would have more because the crank is twice as long. A straight 8 however is more balanced than a 90 deg V-8 in regards to 1st and 2nd order harmonics since the crank throws balance each other out. Whether the crank length and vibration would matter I don't know, the 90-deg V-8 has heavy crank counterweights, and an inline-4 which is probably more common has 2nd order imbalance and both can go many miles/hours so I don't think it's that big a deal regarding durability.
the thing is though, if you're thinking about changing the common 90-deg (cross plane crank) v-8 design for something better, yes an inline-8 is one way to go.
But there is the single plane crank v-8 that's used in race motors where the crank throws resemble that of an inline-4 crank, so it has 2nd order balance problems but the evenly spaced firing pulses allows for better exhaust tuning and it doesn't need crank counterweights so it has less crank mass and can accelerate faster, hence the use of it in race motors I suppose would mean it performs better than the crossplane v-8 crank so why not go with a single plane crank?
In regards to going to an inline-8 over a v-8, consider a v-12 is inherently balanced on 1st and 2nd order, it has 4 more cylinders over an 8 cylinder hence better output, and is 2 cylinders shortly than an inline-8.
There were some people who modified them...
Or even a W configuration. I believe that its BMW that makes a W12 configuration motor. It has a near flatline torque curve
As for an I8, that would be interesting. Maybe for a coupe/truck with a long nose it would fit?
