How important is Exhaust diameter
Does a larger exhaust improve power on a high overlap (10 degrees) cam?
Is there a way to measure exhaust restriction? How do you calculate header diameter for a given overlap?
would think flow might not have *as much* of an effect on valve timing
as the pipe dimensions will. This is just an assumption based on the relationship
between frequency and amplitude however.
I've been studying. Not sure if there's much benefit of having a 2" primary on
a 1.5" exhaust port (for example).
I wouldn't expect to see this sort of crude transition between intake runner and
intake port.
You could weld a small tube into the exhaust just before the muffler or somewhere behind the header, and attach a pressure gage with a piece of flexible (insulating) tubing.
Perhaps overlap is not the driving force for determining header diameters. HP per cylinder might be the first consideration.
Patrick G's current set-up is one of the few cars to perform very well with a cam approaching 10* overlap at .05 and cats, so it can be done.
A restrictive exhaust will certainly contribute to poor street manners on a car using a MAF
For what it's worth, after working with my Dynomation engine simulation program, a 7,500 RPM 433 LSx with ETP's 240 cc C5R heads, which I'm speccing out for a road racer, looked best with stepped 2 -1/8" to 2-1/4" pipes, whereas the Vizard formula gives 1.93" ID, or ~ 2 -1/16" OD.
Flywheel horsepower is a fairly good guide for exhaust pipe size. Your goals are free flow and minimum back pressure and, for a street car, a sound that you and the law can live with.
Mufflers can be the biggest restriction in the system, and if yours don't have adequate flow, big pipes in front of the muffler(s) don't help much, because the muffler acts like a plug in the system. Good choices are Magnaflow and Dynomax Ultra or welded. All of these are flow-through designs with no baffles. There are some other mufflers which sound great, but don't "flow" like the ones mentioned, inspite of their name.
If you have adequate flowing mufflers, choose pipe size by HP you have at the flywheel. If you are using true duals, 2-1/2 inch pipes will support well over 400 fwhp. Note that the new LS7 has 3 inch true duals. They are oversized for the 505 fwhp the engine now has. They should support 600 fwhp.
If you have a Y-pipe into one exhaust pipe and muffler it gets tougher. You should compare inside area of different diameter tubes to estimate flow.
2 pipes each 2-1/2" outside diameter (OD) have about 35% more flow area than one 3 inch OD pipe. However, because there is about 65% more surface area in the 2 x 2-1/2 pipes, they won't flow 35% better than one 3 incher. Similarly, one 4 incher has about 35% more flow area than two 2-1/2 inchers.
OK, so if you are in the 400-450 fwhp range or about 350 to 400 rwhp, 2-1/2 true duals or one 3 inch after the Y should be adequate.
If you plan to do a bunch more to your GTO, look into a 3-1/2 inch pipe after the Y or maybe even 3 inch true duals. For the GTO as it is or the Yukon, a 3 incher after the Y should be plenty, as long as you have a good muffler. If you want true duals, 2-1/2 should work.
Make sure you have a free-flowing muffler(s)!
My $.02
Wouldn't it be wiser to just send the pipes as straight back as you can get them?
IMO, flow is Job One.
At what point does the length of exhaust not matter? And by that I mean at what point will the length stop helping with scavenging and the flow will not benefit from a longer pipe.
Wouldn't a shorter pipe, stopping around mid-car flow best? It would still allow for LT headers for optimum performance, and still give the neccessary flow, without the added weight of extra piping.
Again, I apologize if these question are too remidial for this section.
Every engine combination will have a best header extension length, depending on rpm range and where you want it to perform best. That could be less than 18 inches from the header to maybe 4 feet.
Dumping exhaust at mid car is VERY noisy on a street car.
Your questions need no apology, IMO.
