Advanced Engineering Tech For the more hardcore LS1TECH residents
Do Belt Cam Drives Add Horsepower?
Old 03-16-2006 | 11:39 PM
DavidNJ's Avatar
Default Do Belt Cam Drives Add Horsepower?
I can see how they may be more stable, however I've seen claims of 10-15hp.
Is that true? Is so, how?
Thanks,
David
Old 03-17-2006 | 12:05 AM
SStrokerAce's Avatar
The advantages come in more accurate timing and no transfer of crank harmonics to the camshaft.
Bret
Old 03-18-2006 | 11:19 AM
racer7088's Avatar
Thumbs up
Thanks,
David
What bret said and they are mini variable valve timing in that they retard a tiny amount on top as well depending on the belt and the cam and the spring load.
Old 03-18-2006 | 02:50 PM
Yeah I wasn't going to mention that much since the average cat can't do that.
Bret
Old 03-18-2006 | 03:58 PM
Adrenaline_Z's Avatar
How about weight savings - rotational mass? The ability to divert oil to other
areas of the engine.
A belt system also improves the life of the bearings correct?
Old 03-18-2006 | 06:24 PM
DavidNJ's Avatar
Could you elaborate?
Old 03-18-2006 | 06:30 PM
Does that mean as RPM increase (with the proper components), the belt will
stretch under load and retard the cam?
What are the expected results, half a degree? Two degrees of cam timing?
Old 03-19-2006 | 03:00 PM
A degree or so of retard, which will help the higher RPM.
Bret
