F-body Aerodynamics
areas on the surface of a rolling F-body.
I would like to put the air inlet tube at the highest and dump the
cutout at the lowest.
I have never seen any real info on this.
Best place for an intake: at the base of your windshield (Ever wonder why the climate control systems intake is located here?) I'm not an aerodynamic guru but I don't think the pointed noses on these cars allow enough pressure to build up in font of the bumper to be useful. It has to do with the small distance the air has to travel to get "around" this region. But then at the base of the window you are now moving a lot more air out of the way and this region is still far enough away from the roof for the pressure to be greatest (once you get to the roof the air slows its acceleration.
Best place for exhaust: on the top side of the bumper. You'll want to find the "sweet-spot" here. The good thing is that the faster you drive the bigger and more powerful this sweet spot becomes.
Last thing to consider: What kind of head losses or gains are you going to get by routing extra plumbing to these optimum areas?
But a lot wrong too.
Simply put, if you have an intake there, there is no possible way for it to be the same spot as there is maximum pressure.
Maximum pressure occurs only at what's called a Stagnation point. which is the point at which the flow across two areas of a car separates. think of it as the point of a knife that's cutting through the air. the very edge of the blade has the most pressure on it.
to get the most out of an intake, you would place it in front of a high-drag area, to eliminate the drag at that point, and use it effectively.
The base of the window generates a vortex that spins air forward along part of the hood and creates lots of drag. that's why cowled induction helps so much. but to get maximum performance from an intake, put it at the base of the bumper and put a solid or mostly solid grille on the nose.
exhaust pipes are in the correct location to provide a negative pressure from the slipstream behind the car from the air below it.
the area above the trunk lid is extremely turbulent and has no positive flow characteristics, so that is a bad choice for anything, including exhaust.
honestly, an SS-style hood is very effective, because it scoops air from the hood all the way up to the ram intake, which is also pulling it in, so it doesn't create any drag either.
just an Aerospace Engineering student's .02
I agree with the slipstream assessment of the exhaust. The area that the air that moves the fastest has the lowest pressure. It would need to be below floor level...which is possibly going to cause clearance issues.
like this
http://i2.photobucket.com/albums/y11...n/IMG_0056.jpg
http://i2.photobucket.com/albums/y11...n/IMG_0057.jpg
You should rig up a pressure transducer inside your airbox then record the data as you slow from about 140mph in neutral or turn the engine off (that could be dangerous though)
I see the sawzall coming out!
I don't see any better way to do it as long as you kept the bend over the cowl sufficient enough that it would'nt become a restriction.
Thoughts?
Thoughts?
Mind you, I have no bumper support or ac system or anything, so cutting my core (for a straighter shot to the intake), removing my factory lower air box, and zip tieing the radiator forward would be alot easier than working with all the factory systems in there.
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
