Project Budget 10 Second Camaro Thread
Old May 17, 2009 | 11:31 AM
  #181
caldercay's Avatar
Originally Posted by Black94Z28
[snipped]
I need to come up with a better way to keep the plug wires from touching the headers. Any other ideas other than the zip ties Im using?
http://picasaweb.google.com/calder.c...75703425007154
Old May 17, 2009 | 07:41 PM
  #182
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
The lid looks nice. You should post some pictures of the bottom side of the hood so people can see all of your trimming.
Old May 17, 2009 | 10:52 PM
  #183
collier341's Avatar
great work so far! kudos on doing it all without a garage
im going with the wire setup on the right.. gets the wires away from the heat and doesnt look tacky like the OTVC setup
Old May 17, 2009 | 11:18 PM
  #184
hawk584's Avatar
will this cause an exhaust leak?
Old May 17, 2009 | 11:24 PM
  #185
SoxXpupPeT's Avatar
what will ? the slit between the flange ? i doubt it. my macs dont leak there. they actually leak on the passenger side where there is no split. i would probably be alot better if there was a split there allowing the flange to sit flatter on the head. and yes. OTVC FTW! i did mine and made my own taylor wires. it came out nice IMO
Old May 18, 2009 | 01:35 AM
  #186
A20SVT00's Avatar
awsome work being done let the pics keep on coming
Old May 19, 2009 | 04:41 PM
  #187
Black94Z28's Avatar
Got some progress done on my car and actually street drove it for the first time since November. Drove about 20 miles and knock on wood, so far so good. Going to try and drive it to work tomorrow for the true test (60 mile round trip)
First cleaned her up BTW, the wheels are temps till my Weld ProStars come in.
And I promised pics of the underside of the hood where I cut for the LS1 lid. Granted this is a rough cut and will clean it up with a dremel soon, but here is what was taken out
The LS1 lid and base setup...
Then went down to McHenry Muffler and Dana ran true duals for me for a really reasonable price and really happy with the results. Dual 3 inch to 3 inch Race Magnum mufflers with turn downs. Sounds pretty tame at idle which I was looking for, but the second you give the LT1 gas, it sounds beasty Ground clearance is about 3 inches, so not too bad IMO
Old May 19, 2009 | 05:04 PM
  #188
collier341's Avatar
exhaust looks nice.. we need a sound clip now no x or h pipe?
Old May 19, 2009 | 05:24 PM
  #189
OWN3D BY MY PROF!
On the turn downs angle them at a 315* angle (full circle measurement) and it should help with the interior sound. If you put an H in there it will help with the sound, power, and flow even more. It's pretty simple at this point too.
Old May 19, 2009 | 09:16 PM
  #190
z28rob18's Avatar
exhaust looks good. you need some new suspension parts in the rear and possibly new rear
Old May 19, 2009 | 09:19 PM
  #191
SoxXpupPeT's Avatar
agreed! youll need some good suspension parts under there to get you into the 10's
Old May 19, 2009 | 09:45 PM
  #192
Black94Z28's Avatar
suspension is next on the list, i want to do suspension, rear end, trans and then the engine last. hopefully it will last long enough to hold me over.
Old May 19, 2009 | 09:49 PM
  #193
AChotrod's Avatar
Looks good!! I wish too
Old May 20, 2009 | 06:03 AM
  #194
z28rob18's Avatar
i figured you were doin it that rear and panhard bar just look lik theyve seen better days
Old Jun 5, 2009 | 06:28 PM
  #195
Black94Z28's Avatar
Well finally bit the bullit and ordered some Weld ProStars. I got for the front 15x3.5 with 1.75 backspacing and 15x10 with 7.5 backspacing. For the front tire, I went with the VW tires (165/80r15) and the rear tires I ordered some Nitto 275/50r15 Drag Radials. Those havent come in yet so found some scrap 245/60R15 BFG Radial TAs for the rear till those come in.
Front ProStar and 165 Tire...
Rear ProStar and BFG Radial TA Tire till my Nittos arrive. Also installed ARP 3.25 inch wheel studs (yes, i needed to pull the axles to do this)...
Also figured since my final goal is 10s, I ordered a Competition Engineering 8 point roll cage to stiffen the car out and for safety issues. I also am ordering SFCs this week to so going to do all this at once.
And washed the car and took some pictures of the Camaro with the wheels on. I love how the car looks now, just cant wait to have the hood painted
Old Jun 5, 2009 | 11:47 PM
  #196
Driftunit's Avatar
time for a new sig pic lol
Old Jun 5, 2009 | 11:58 PM
  #197
Black94Z28's Avatar
Just about to request one, unless someone can whip up one
Old Jun 6, 2009 | 06:24 PM
  #198
ktraver97ss's Avatar
Nice build mike, if you ever need a hand let me know.
Old Jun 6, 2009 | 06:39 PM
  #199
joelster's Avatar
Cool build. I haven't read the entire thread so forgive me if this questions have been answered before.
I know you are on a budget, but those front tires weigh about 18-19lbs apiece, I used to run them. The Moroso bias-ply weigh 9-10 depending on which ones you get. That is 20lbs of unsprung weight which is huge. What made you go with the radials on the front?
I see you still rock the stock style battery. You NEED to get an odyssey PC680 or equivalent. It will shed 25-30lbs right off of the nose. Any plans for a new battery?
You are going to get booted from tech inspection for your front wheel studs being way too short. They will check this too.
Rollcage. Did you get chromoly or no? Those bolt-in chromoly cages from SW or wherever usually weigh 20-30lbs less than the mild steel ones. It's worth every penny since they typically only run $150-$200 more. $10 a lb is a good investment.
Old Jun 6, 2009 | 08:26 PM
  #200
moderate Z28's Avatar
Man now that thing looks like a REAL car!!! Nice work so far.
