Project Budget 10 Second Camaro Thread
I have the water pump off right now since I am swapping out opti's, so took a picture of my water pump. You can see where I capped off the 2 outlets. You can buy the bypass caps at any parts store for a couple bucks and just put a clamp over it. Havent had any problems so far.
2. has anyone ran hoodpins in their stock hood to eliminate the hinges, latches, and plungers? May sound crazy, but it could be a fairly cheap way to eliminate ~6-7 lbs off the front end
You mean the plastic tube thing that laying underneath the header? I believe it was something for the windshield washer fluid, like a pump or something. Whatever it was though, its gone
purge solenoid on the passenger side of the intake.
And "fat" my car ran 9.069. Skinny now it runs 8.55.
