first attempt at wet sanding
Old Dec 22, 2008 | 03:40 AM
GoFast908Z's Avatar
Default first attempt at wet sanding
Well tonight I took the plunge and made my first attempt at wet sanding. I picked up an extra Z28 spoiler to experiment on and here are the results.
What I started with:
After 1000 grit
After 1500 grit
After 2000 grit
First stage of polishing:
Makita Rotary @ 1500 rpm, Lake Country Yellow cutting pad, Menzerna Power Polish
Second stage of polishing:
Makita Rotary @ 1500 rpm, Lake Country Orange pad, Menzerna Power Polish
Third stage of polishing:
Makita Rotary @ 1200 rpm, Lake Country Orange pad, Menzerna Super Intensive Polish
Fourth stage of polishing:
Makita Rotary @ 1200 rpm, Lake Country white pad, Menzerna Nano polish
Fifth and final stage of polishing:
Porter Cable @ speed 6, Lake Country blue pad, Menzerna Nano polish
Side by side difference of before/after:
No more orange peel on the test section!
Old Dec 22, 2008 | 03:44 AM
phantomzer0's Avatar
Wow, ******* awesome!!! Great job dude!
Old Dec 22, 2008 | 04:42 AM
ZMONSTER!'s Avatar
Wow dude that looks great!
So are you supposed to do that to an entire car? Looks like it took a long time, but the results are awesome!
Old Dec 22, 2008 | 04:54 AM
chavez885's Avatar
Damn, great work!!
Old Dec 22, 2008 | 05:29 AM
GoFast908Z's Avatar
haha thanks guys!
I will be doing my entire car as further practice
Old Dec 22, 2008 | 06:22 AM
The Guz's Avatar
Nice work.
Old Dec 22, 2008 | 06:40 AM
italicizedsponge's Avatar
simply amazing
Old Dec 22, 2008 | 07:23 AM
H21surfer's Avatar
awesome results!
Old Dec 22, 2008 | 07:54 AM
5PONT7's Avatar
Nice, those marks are always a pain to get out.
Old Dec 22, 2008 | 08:00 AM
99zee's Avatar
Great work. Yes, its alot of work but look at the results. My entire car needs to be done
Old Dec 22, 2008 | 08:37 AM
02gtp4now's Avatar
nice job, i would start with 1500 only in the areas where there are scuffs and minor imperfections, then do the car with 2000. this way you dont remove so much of your clear. also instead of going thru 6 steps of polish use a mid grit compound for the first buff, then move on to polishes. you did a great job but this will help to speed up your process with the same results.
Old Dec 22, 2008 | 08:42 AM
AxisOfOil's Avatar
simply incredible.
I may have to do this to my entire car instead of getting new paint... lol.
Old Dec 22, 2008 | 08:44 AM
Chief Z's Avatar
Nice job. Its is always satisfying to get in there and experiment and get good results. Small sections for the whole car. I would suggest masking out a section at a time so you dont get ahead of yourself. I normally end up doing way more than I intended to when I start a project like that. Good luck.
Old Dec 22, 2008 | 08:55 AM
Havok2's Avatar
you shoulda buffed the part next to it, without sanding see how that would look?
Old Dec 22, 2008 | 09:01 AM
Randy WS6's Avatar
nice job.
Old Dec 22, 2008 | 09:04 AM
firehawk#682's Avatar
alot of work but its worth it in the end
Old Dec 22, 2008 | 09:30 AM
TORCHD 02 TA's Avatar
Great work. Too much for me. But the end result is what makes you happy.
I like this pic, shows how good of a job you did
Old Dec 22, 2008 | 09:45 AM
hlaalu's Avatar
i was going to say the same thing.
Old Dec 22, 2008 | 10:03 AM
SKI's Avatar
SKI
Good Job
Old Dec 22, 2008 | 01:24 PM
PERFECT Z28's Avatar
Looks great buddy!
