- Camaro and Firebird How to Sequence Tail Lights<br>Step by step instructions for do-it-yourself repairs.
HOW TO: Sequential Tail Lights
We'd need LOTS of work to make this work for our cars. There are 2 ways to go.
1. If you get the STS 2 kit, you'll only get the outer 2 lights will work, (and you lose your turn signal from the original spot, it just wont light up) Also, your brake light will only be the middle section of the tail light.
2. If you get the STS 1 kit, you'll need to run a trailer harness box. Essentially you cut your harness and run it to the new trailer box. (trailer boxes are the same ones you would need to tow a trailer with your car. They only have one light and it's both the brake and turn) You'll basically be sending the light signals to that "box" then that box will connect to the STS 1 kit and THAT will now make all the bulbs in the sequence light up OR signal. (The STS 1 kit sends out 1 signal so the trailer box is needed to send it out to the multiple bulbs)
He also said doing the trailer box it's way more of a pain, and they dont want to hassle with making it because the demand isn't there for that kit.
I may try to do the sequential one for me, but it isn't a mod I can actually see so I'm on the fence about it for now.
Thats the site. i dont know what car you have, so i cant tell you what kit is for you.
