Old May 20, 2016, 02:10 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Chevrolet Camaro or Pontiac Firebird Lighting Guides
Print Wikipost
HOW TO: Sequential Tail Lights
Old May 18, 2012 | 12:46 AM
  #141
Kujo79's Avatar
It shows how to slow down the timing of the STS....This is a video i did on how to Mod a OEM flasher and the differance between OEM, EL12, OEM Modded Flasher. This may help or may not ,Let me know Thanks
I recorded In HIGH def, sorry if I talk to much just tryin to cover everything
http://youtu.be/zJidPmAE5W0
Old May 19, 2012 | 07:20 AM
  #142
JOHNNY59's Avatar
excellent job on the flasher mod and video!
Old Jun 1, 2012 | 06:39 PM
  #143
awake1630's Avatar
i installed this kit on an 01 Trans am.
Followed the directions to a T.
Now the front directionals do not work. With the four way or the blinkers. Nothing.
They light up with the lights on but do not blink.
anybody else experience this.
Old Jun 1, 2012 | 06:56 PM
  #144
wssix99's Avatar
Save the manuals!
Something isn't installed correctly and you aren't pulling enough power for your flashers. If you go to electronic ones, you may be able to debug easier.
Old Jun 1, 2012 | 07:07 PM
  #145
awake1630's Avatar
what do you mean can you explain more?
i installed this kit http://www.webelectricproducts.com/products.htm
electric what? Flasher relays?
Old Jun 1, 2012 | 07:16 PM
  #146
awake1630's Avatar
the blinkers and flashers work fine in the back after the install. But the fronts do not work on either blinker or flasher
Old Jun 1, 2012 | 10:46 PM
  #147
wssix99's Avatar
Save the manuals!
What kind of flashers do you have installed and did you do anything to the fronts. (Change bulbs, mess around under the dash, etc.?)
Old Jun 2, 2012 | 07:52 AM
  #148
awake1630's Avatar
no front wires were messed with.
No under dash wires were messed with.
http://www.autozone.com/autozone/par...247229_0_7284_
thats the flasher relay i put in a couple of weeks before the install.
Old Jun 2, 2012 | 09:52 AM
  #149
DaRReLL's Avatar
I'm getting ready to install some LT1 tails. Willl the kit from WebElectric work for a 2002 camaro too? I really don't want to MOD the outside light to a different one.
Directly from the the website quoted below.....
The STS-3TA Sequencer Kit will convert the tail lights on your 1993-2002 Firebird or TransAm to sequential operation. This kit is specifically designed to convert the outer tail light bulb to brake/turn/tail light operation without modifying your tail light housing or replacing sockets.
I just seen this....
Note: Sequential Turn Signals only work on cars with combination brake/turn signal lamps. They will not work on cars with separate turn signals or cars with amber lenses. This kit will not work with LED lamps, only standard incandescent lamps.
Am I screwed?
Old Jun 2, 2012 | 09:57 AM
  #150
awake1630's Avatar
You have to change the socket for the camaro
Old Jun 2, 2012 | 08:10 PM
  #151
Carguy8888's Avatar
Awsome mod defintly on my list now. Will someone point me towards the drl switchback mod. I would like some red lights where my drl's are but i don't want to get cuffed & stuffed. Thanks.
Old Jun 3, 2012 | 09:37 AM
  #152
wssix99's Avatar
Save the manuals!
Your DRL module is probably hosed then. You should probably also make sure the sockets are good before going there. Its possible, both sockets could have gone out on you at the same time.
Old Jun 3, 2012 | 09:40 AM
  #153
wssix99's Avatar
Save the manuals!
Am I screwed?
The kit comes with a different bulb to use in the outer socket. Everything you need is in the kit. Its not really a "mod."
As long as you use incandescents and not LEDs, you are fine.
Old Jun 3, 2012 | 09:38 PM
  #154
Kujo79's Avatar
Yea mine came with a 921 bulb that replaces the 168
Old Jul 14, 2012 | 08:07 AM
  #155
Black-n-Sleek's Avatar
Is there any kits that I can purchase and use led lights? I have a thundercat kit in the car now. "trans am" I may have to remove it because the outer driver's bulb is not lighting and it seems that it is not getting any power.
So I'm trying to weigh my options.
Old Jul 15, 2012 | 02:17 PM
  #156
ARLS1's Avatar
For about $15 you can build a couple of these...
I'm no engineer, just a hobbyist, so my schematics may not be the best. But it works.
I have the boards built and ready to install and troubleshoot but I'm in the middle of the engine rebuild so it will be a while before I finish this up.
Old Sep 9, 2012 | 10:20 AM
  #157
Carguy8888's Avatar
Originally Posted by 99'CajunFirehawk157
That is awesome, i put it on my list of Winter projects. What is the name of the song please. I don't rember it as any VH song. Thank you.
Old Nov 19, 2012 | 11:30 AM
  #158
stroked383HSR's Avatar
ok so I hate to bring up such an old thread but....I want the kit to do my lights like above.
whats the kit everyone is using? show me the way
Old Nov 19, 2012 | 12:27 PM
  #159
TallgeeseIV's Avatar
I bought this one, very easy install, and looks fantastic.
Old Nov 19, 2012 | 02:03 PM
  #160
was shipping fast? cause i just ordered from them
