My engine bay and engine redo - 98 TA
I am in the process of putting the new engine in my car, but this turbo setup is REALLY pissing me off and I'm starting to think the car is going to be a hell of a lot less streetable because of it. My quest for a turbo car may have clouded my remembrance of what I'm actually going to do with the car - drive it on the street.
I have the eBay PTK knockoff, which is actually a pretty nice system and I have fixed the little bullshit that was wrong with it, so it is a really nice kit. I have a 70mm turbo with it, brand new, and an eBay intercooler setup with piping and tubes and all.
The engine is an LQ9 that I won't be able to run too much boost on anyway.
With the turbo I'll have to remove the AC, convert the cooling to pusher fans, relocate the alternator, install solid motor mounts, and the system will hang really low so I may have to raise my car up a bit.
I still have to buy:
Dual fuel pump setup
Camshaft
Radiator
Pusher fans
Alternator relo bracket
Injectors
Springs
Probably some other nickel and dime bullshit too.
Now, I can probably sell my turbo kit and everything I have for it for a good bit. With that I could finish off the LQ9 with a big fat cam, maybe ditch my intake and get a FAST 90/90 setup, throw some nitrous on it and maybe do some other stuff. I could probably get out a hell of a lot cheaper, keep the car a lot more street friendly, still make an assload of power, and get it back on the road a hell of a lot sooner.
What do you guys think, talk to me here. I am lost. I really miss my car.
you will have to invest at least another 3k into extra parts, if not more for this kit to work. Plus alot more time. If i was you, I would ditch the kit, and if you are set on turbo then get your car running and save for a kit or all the parts.
Good luck with whatever you decide. I know it sucks not having a car, Been without mine for 8 months now.
I'll keep updating as we go, hopefully the car will be done sooner this way.
317 heads cleaned up, ported, 3-angled, etc. Good performance head build along the lines of what would be considered a "stage 2" build.
Typhoon PP intake
Ported and polished TB
32lb injectors
150 shot from a wet nitrous kit
Dual valve springs
Unsure of cam, maybe an MS4 or Polluter.
I'm going to hide everything where the air pump used to be. I'll trim out the area in the fender well for access to make a bigger hole, then fabricate a nice panel to cover it and attach it with stainless fasteners. That way it will be smooth and painted and good looking, but if I ever need to access my fuses or my proportioning valve I can just unbolt it and have access to it. The brake lines I am going to run backwards from the master cylinder, then drop down in the area between the firewall and fender through a rubber grommet. I'll then run the lines across the inner fender under the liner and out through the front. That way they will all be out of the engine bay.
On the passenger side, I'm going to smooth out the battery tray area, ditch the factory overflow can (which I found out was broken anyway!) and run a catch can either on the firewall or underneath where the old one used to drop down.
Trying to find a place to hide the PCM too.
Wish I could do something different with the A/C, but I'm just not going to remove it. I have two small kids and having AC is more important to me than a cleaner engine bay.
