Removing "honeycomb" from trans am tail lights?
#44
I have a junk 98+ tail light in my garage (reflector inside the housing itself is damaged and it of course lights up dark).. I may just have to play with the oven this evening. Clears would look AMAZING
#48
FYI, I did play around with my lenses but forgot to post back up. The lenses themselves are died with the red and honeycomb pattern. without bleaching out the die or re-forming our own new lens, you can forget about clears from the stock housings. What I want to know is why no one ever made such a thing as popular as they were when these cars came out! Euro's were all the rage for the longest time haha
#49
When you rip a Mustang owner a new one on the highway, don't you want to send the message that he's been stung like bee? The honeycomb taillights are just another way to get into their heads. You wanna give that up?
#50
honeycomb
This can be done with 98-2002 seen an article looking for it long short it said put honeycomb in oven and the adhesive melts and you can remove red part then you get some more adhesive reseal and you got clears
#51
Here, check it https://ls1tech.com/forums/appearanc...oneycombs.html
also don't bump 3 year dead threads to add misunderstood info. the info you supplied is a short version of how to remove the lense and reattach it, NONE of that magically makes the red disappear.
also here is a shot that will make it clear the red can't be removed from the black honeycomb.
#55
Are you asking about custom tail lights for our F-bodies? The only company that provided us with a product for a short time was 6LE Designs, but the company is now out of business.
http://photobucket.com/gallery/user/...mpwZw==/?ref=1
http://photobucket.com/gallery/user/...TQuanBn/?ref=1
I was very fond of the last picture from 6LE Designs, the "Heritage" design. The only problem, this mod is clearly not DOT specification, and I want to have those reflective diffusers molded into the plastic overlay of this housing. I did a search online and perhaps using transparent red tail light repair kit would have addressed this issue although it does ruin the feeling of having new tail lights but rigging them with tape to look DOT compliant.
The other better option is this...
Home made "retro" tail light write up Reply Subscribe
It sure beats the hell out of this look on my Trans Am. These tail lights were saved off of my first car, so at least I do still have them to perform this mod. I will admit, I do like how they looked at night time compared to my Trans Am lights, AND, without the removable reflector they actually lit up with more surface area like the honeycomb tail lights.
I do like the honeycomb tail lights. My grid tail lights are worn out and I am fighting a losing battle to keep moisture out. Plus, if memory serves me, my base firebird tail lights are awfully dim during the daytime, perhaps the back reflector is flaking the material. I may have to pick up some decent used honeycombs at some point. Clearly the fourth-gen community is in need of aftermarket tail lights, whoever is able to fabricate them and make a profit on them, Mark.
#56
There ones from 6le were way too expensive and you didn't get much for what you were paying for. (Just the lenses) not sure why there weren't any Chinese companies making cool custom tailights for our cars like the rest of the junk that was out.
#57
It is still irritating that the Camaro has aftermarket tail light support while the Firebird is nonexistent. I understand, trying to get plastic molds for these tail lights would be expensive and then the need to mass produce them at a profit to justify what you spent to even produce one! I am not sure if you can get away with a crude version using fiberglass but then the problems with getting the reflectors made. Whoever makes the aftermarket Camaro tail lights, for God sakes, can you start making the Firebird versions?!
The best we can do is try to carefully pry apart existing housings without breaking the damn things, spray paint in chrome mirror finish the reflectors, and paint the grids/honeycombs back on the exterior lens or perform the "heritage" mod on the base 6-cylinder firebird tail lights, which I am very tempted to do since I have grown tired of my grid tail lights and the honeycombs are also too dull and lack the statement I am looking for. However, I want more red light to show on the "heritage" mod so I would have to see what I could do, maybe make the lines thinner and leave some room for the outline of the tail lense where it still shines, something like this.
Note, this amazing as hell custom job on this Trans Am uses an LED system that is not easily serviceable if a few stop working correctly and the wiring/soldering work by this guy takes 3 months. I would be happy with LED socket bulbs and the painted heritage look on the base firebird tail light lenses.
#59
Copy & Paste Moderator
Plus, they were not DOT spec tail lights with the built-in reflector/diffusers that you see on the firebird base, grid, and honeycombs. However, newer cars I notice don't have them. If you really wanted that "look", the tail light repair kit might have been a good solution to apply on the inside of those lenses.
#60
You may be right. I did have a chance to look over another such car with clear lenses and there was something off to the side of it. I suppose they do require some reflector which goes back to my concerns about the lenses that 6LE Designs were offering when they were in business; such reflectors were noticeably missing from the pictures I saw of the clear and heritage lenses offered. I would hate to get pulled over by a very astute police officer who can tell my tail lights were illegally modified and no longer DOT certified. Plus, in the event you had a blown fuse with your tail lights, which happened to me once with my first Firebird and I was pulled over for it, you need reflectors in absence of lights in the dark of night. A simple solution to this problem is a tail light repair kit with patches that include those reflectors.
