engine bay power washing...
Anyways to the point.. would you guys recommend Power washing it down a little bit.. i did it to my "beater" Saturn when i got it and it was fine, also on my old DSM i believe and on my buddies. but theres more electrical wires under the hood of my 98 Camaro.. any advice or past expieriances to share with me would be great. Looking to clean er up this weekend
One must be prudent, though. Don't stick the wand right up into everything and spray it like you're washing away your ex-wife's bad mojo. Hold the wand a ways back wherever there are wires and connectors. I even let the car sit a while to cool off the exhaust manifolds. I cracked one on an older truck of mine, I think because I didn't let it cool before I started spraying.
Good luck. Have some towels handy. WD-40 might not hurt, either.
The purple stuff is a really good degreaser also, just as long as your carful i guess is the main issue. I wouldnt just spray the whole engine with anyone thing unless just som mild soap, i think the best thing to do is just take your time and detail it. Or be lazy and do it quick, but you do take a risk whether its big or not or worth it is up to whoever doing, ive heard enough to decide to just take my time, normaly takes less than 10 min anyways..
Also be aware of the TSB about water getting in the knock sensor wells under the intake. You might want to look it up.
It says knock sensor corrsion and failure in cars is caused by excessive underhood washing (or something to that effect).
I found that TSB after the second time I washed my engine with simple green automotive. I even used hp tuners to shut the fans off and let it run at factory set temp for a while trying to get any water to evaporate out, if it did get in there.
But apparently it didn't work because in a week it threw knock sensor codes, the front one was rusted bad. This is on my SS that is garage kept and had 33,000 miles at the time.
Right now I have a set of intake gaskets for my Z28 so I can take it off, seal the knock sensor boots and be able to clean it with no worries.
