Ask a Professional Detailer
M101+orange lc pad takes a lot of passes. It doesn't help that the previous owner had to have gone through swirlomatic car washes the car's entire life. Wish I would've bought mf pads.
I guess I'm going to have to learn to deal with some of these RIDS. Luckily, my paint is white.
How much does a shop charge to fix that on average?
A real professional detailer will charge 1k+ usually.... for a very good reason.
It shines good but has a lot of minor scratches and swirls in sunlight/halogen light, I am interested in purchasing a porter cable or a similar buffer but wanted to know which products would be good on this paint? it's a bit darker then most.
Also, the car is originally from florida, I just noticed on an overcast day that parts of the hood on the passenger side are small blisters/bubbles only visible in certain lighting, and parts of the rear deck lid but not much there, I was wanting to know if this is able to be corrected with cutting/polishing or would it make it worse? it seems to be in the clear coat but I'm not 100%. it's mostly the hood tho, all side panels are perfect, I'm thinking the sun baked the paint on some of the flat services.
Thanks!
As for the bubbles....I have no way of knowing without seeing it. Sounds like paint separation to me.
Every product will have different temperature tolerances. Just thaw them out and try them and see if they still work.
