Ask a Professional Detailer
Old Jan 31, 2013 | 08:47 PM
  #2041
gMAG's Avatar
This video is just the thing, and what the moderator describes, is exactly what is going on with my paint, and explains why the rough parts are those on top ("horizontal"), and those exposed to air currents.
I'm psyched about using the clay to correct the paint finish.
Thanks, Gents!
Old Jan 31, 2013 | 09:02 PM
  #2042
LilJayV10's Avatar
Sweet man. Glad it helped you out.
Old Feb 2, 2013 | 09:31 AM
  #2043
AWDTBSS's Avatar
I'd suggest using the plastic sandwich baggy trick to make sure you got rid of all the contaminants. All you need is a plastic bag I use a sandwich bag and just stick your hand inside it and gently glide it over your paint to see if you need to keep claying that section or your good to go
Old Feb 2, 2013 | 11:57 AM
  #2044
LilJayV10's Avatar
Quoted for truth. I didn't mention that because I thought it was covered in Mike Phillips video.
Old Feb 2, 2013 | 12:21 PM
  #2045
dabest09's Avatar
Originally Posted by egott_91
My suggestion would be to clay also. On a daily driver I've heard suggestions of claying as often as you change your oil. I usually do it at least 2 times a year on the truck, in the spring and fall. The SS rarely sees rain or anything so it usually only gets clayed in the spring.
Spot on. I'd say a daily driver truly needs clayed every 4-6 months. Maybe even more often depending on how often it is washed and what lsp is on it. I used to HATE claying with a passion until I got my speedy prep towel. Now I don't mind doing it as much. Makes sealing and waxing like a breeze.
Old Feb 2, 2013 | 03:07 PM
  #2046
egott_91's Avatar
Thanks, Gents!
Just to be clear, the clay will not do any amount of paint correction, it will only remove the contamination that is present on the clear.
Old Feb 2, 2013 | 04:55 PM
  #2047
blknSS's Avatar
Maybe this was answered in this thread....its kind of long so refer me to what post if it has been answered.
I desperately need to degrease/clean the engine bay. Nervous as hell to be spraying gunk and water around all that expensive electrical ****. Tips/trick/advice? Thanks in advance.
Old Feb 3, 2013 | 11:35 AM
  #2048
egott_91's Avatar
Most modern vehicles you're fine spraying the motor down.
1) make sure the engine isn't hot/warm
2) cover any exposed filters
3) use a light stream of water (fan spray)
4) spray a degreaser/all purpose cleaner
5) use a brush to get into the nooks, crevices, crannies
6) let dwell for a few minutes
7) spray off degreaser/all purpose cleaner with a light stream of water
8) use a leaf blower/compressed air/car dryer to remove standing water
9) turn engine on and let it idle to burn off the remaining water (after removing the covered filters)
10) once engine is cool after letting it idle, apply a dressing to the plastics to protect them and just make them look 100 times better. Just don't use anything too greasy or it'll collect a **** ton of dust... Best bet would be to apply the dressing and then knock it down by going back over it with a towel
Old Feb 3, 2013 | 11:52 AM
  #2049
LilJayV10's Avatar
It's also a good idea to cover the pcm, alternator and relay/fuse center with aluminum foil or plastic wrap to prevent water from getting in there.
Try and use a non silicon base spray for the engine compartment. It doesn't attract dust and doesn't have that 'just bought it from the dealership look' unless you like that kinda thing.
Old Feb 3, 2013 | 03:05 PM
  #2050
gMAG's Avatar
We live closeby & downstream to the highway. At times, you can smell the pollutants in the air, especially when the air is cool, and forces the pollutants
to hang low. I think that alot of the crud on the paint is just that.
Looks like the car will be done at least a couple of times a year.
Old Feb 3, 2013 | 05:52 PM
  #2051
05TurboCGM's Avatar
I have this on my beater which looks like some bad water spots. You think some m105/205 combo would take this off?
Old Feb 6, 2013 | 09:38 PM
  #2052
TxOutlawZ28's Avatar
I recommend superbrightleds.com and use RET71 as a coupon for 5% off.
anyone know what item number is for the lights in rearview mirror and where I may be able to find a write up on install thanks in advance
Old Feb 8, 2013 | 12:27 AM
  #2053
shepss217's Avatar
hey man thanks so much for doing this thread, i've had a question about my wheels and just wanted to know where to start, i bought some aluminum drag wheels and 1 day while cleaning the tires with bleach white it got on the wheels and damn near destroyed them, there's white powdery stuff all over the finish and stained like crazy. How can i get the wheels back to new or almost new?
Old Feb 8, 2013 | 01:01 AM
  #2054
DropTopBird's Avatar
Whats the best way to get road paint off a car? The lady got stuck on the turnpike behind a paint truck and got some spray on her car.
Old Feb 8, 2013 | 11:03 AM
  #2055
mac62989's Avatar
I remember Jeff touching on this earlier in the thread. Road paint is meant to take a beating and from what I remember its near impossible to remove. I think Jeff told a story how some exotic got road paint on a lot of the car and it was totaled..
Old Feb 8, 2013 | 09:53 PM
  #2056
LilJayV10's Avatar
From what I can tell from the pic that looks like that's in the base coat not on top. It looks like there was some sort of issue between the primer/sealer and the base coat. I had the same thing happen on a fiberglass hood I painted last year. I had to sand it back down and use a different sealer to make it work. Again I very well could be wrong.
Old Feb 8, 2013 | 09:57 PM
  #2057
LilJayV10's Avatar
How bad is it? Can you get a pic?
Old Feb 8, 2013 | 10:05 PM
  #2058
LilJayV10's Avatar
After you clean the wheels good, making sure all dirt/brake dust off of them try Mothers mag/aluminum wheel polish with a microfiber towel and see if that takes it off. If that's not aggressive enough you can use the Mothers w/ 0000 steel wool. That combo will leave some marring which you will have to go back over with the Mothers/MF. I have found that's the best way to do the "correction" part and that Adam's Metal Polish 1&2 after that with a good MF. Here are a few pics of the wheels on my T/A. They were stained, pitted with brake dust.
Before
After
Old Feb 8, 2013 | 10:14 PM
  #2059
LilJayV10's Avatar
There is some fine pitting but you have to get really close with a bright light to see it. Only way to fix that is wet sanding and for what the car is used for there wasn't any reason to go that far with it.
Old Feb 9, 2013 | 01:43 PM
  #2060
shepss217's Avatar
ok yeah i tried just mothers and it did help but i need something more aggressive so i will try the steel wool, thanks alot for the info man, i don't have any pitting just really bad stains and dull, those wheels look 10 times better than the top pic, what brand steel wool do you prefer?
