Ask a Professional Detailer
Side not im using 105 right now with a yellow pad on some parts, and a orange pad on some parts. Its drying up super fast and will not stay lubricated. To taked it off im having to wipe it with a damp mf towel. Took me about 3 hours to get this far. The lines in the second pic are reflections of the shed door that was closed and one that was open just for clarification.
This is basically what it looks like:
With all the salt on the roads, the insides likely will if they aren't already. For the faces, just use a good chrome polish once a month (because of the harsh elements) and seal them with a wax or sealant.
Speaking of windows, my glass has scratches in it, not deep but you can see them in the light at certain angles. Is there any way to get those out or reduce them? It looks like the previous owner was trying to get something off the windshield with a flathead screwdriver. Rubbing compound maybe?
For the scratches or wiper marks, I have used a lake county foam pad made for glass with Zaino Z12 with a porter cable DA with nice results. Link below is the pad I used.
http://www.autogeek.net/glass-polishing-pad-5inch.html
And exactly how many pads do you think I would use on my car with the 105/205? I don't know how dirty they should be before I put on a new pad.
Finally, can you tell me exactly what I need to do to clean the pads after I use them. I heard dawn dish soap can make the velcro peel off from the pad and stiff bristles can ruin the pads.
Sorry for all the questions lol I know you're busy.
Can't wait to use my blackfire wet diamond after I correct my paint! Got it 50% off at the sale on autogeek
I will purchase the Z12 and try one of my own buffing pads first.
My car got keyed from the front of the passenger door, over the door handle, and almost all the way to the rear bumper on the quarter panel. At the time I had a high insurance deductible and the insurance adjuster low balled the estimate. So I just let it ride for the time being. This past summer I purchased some touch up paint and decided to repair this myself. I knew from the get-go that it would not be a 100% repair, but it would look a lot better than what it did. I expected something along the lines of a 75% repair- meaning it would be barely visible anymore.
My process consisted of applying wax and grease remover, apply touch up paint, wet sand touch up paint until it was flat with the OEM paint, then use polishing compound and wax when done. I did this process once, and then did it again a few weeks later to try and get the scratch a little better. I would build the scratch up each time to fill it. It went from a deep scratch, to a barely visible scratch that could not be felt with a fingernail any more.
Do you feel as though I can remedy this scratch any more? Or is this as good as it will get without getting a body shop involved?
Are there any 'detailing' tricks that could help me? i.e. blend the paint into the scratch with a buffer and some product?
Thanks
Thanks
