Ask a Professional Detailer
Old Nov 18, 2011 | 02:59 PM
  #501
Rare96LT1Formula's Avatar
Originally Posted by 02ws.sik
Ok i took off the wax and re waxed it and cleaned the inside and door jams and there is no tar. So what is the best way to clean the engine bay?
I had good results cleaning my engine with puple power degreaser and terry towels. There may be better options however.
Old Nov 18, 2011 | 11:03 PM
  #502
Fish-man's Avatar
Originally Posted by GoFast908Z
Oh I misunderstood the question. In that case, Black Magic makes (don't know if its still available) a product thats an aerosol 2-in-1 Engine Cleaner / Dressing. It tends to leave a white residue on rubber hoses, so you'll need to wipe those after, but other than that it works well for spray on spray off. Honestly you won't find better because you really need to scrub it for good results.
303 rubs off on your interior? How do you mean? Like the shine comes off if you touch it? I personally wouldn't apply it to any surfaces you'll be touching.
For the underbody, what are you using now? With the lack of clear/paint coverage you have to clean it gently. Use some detail spray or car wash soap in a spray bottle and wipe it very gently.
I'll look for that black magic stuff...
303 rubs right off... like on the door where I rest my arm.
Underbody I've used simple green at 50% and a couple things I forget what... but have not tried detail spray (seems like an expensive way to clean down there, and its tough to get clean with dirt/grime/grease. Maybe I'll try some car wash soap as you say.
Old Nov 19, 2011 | 12:14 PM
  #503
cwdub4's Avatar
hopefully this is the right place to ask, if not i apologize
I just bought these and knew they were messed up and now I want to fix them, previous owner had tried to clean them with a heavy degreaser and completely messed up the clear coat, so I was wondering if I can strip these myself and not mess up the black...they are OEM GM stamped
Sorry for the big pics but just want you guys to really see what im talking about
Old Nov 19, 2011 | 03:11 PM
  #504
Fish-man's Avatar
The black on those rims deosn't look so good anyway.... might as well strip 'em down
Old Nov 19, 2011 | 08:34 PM
  #505
02ws.sik's Avatar
On the ws6 rims... Do they have clear coat? What is the best way to clean them? They aren't on car but im going to clean them up this winter.
Old Nov 19, 2011 | 08:48 PM
  #506
GoFast908Z's Avatar
Yes they do. Check this thread.
https://ls1tech.com/forums/appearanc...ine-again.html
Old Nov 20, 2011 | 02:51 AM
  #507
2QuikTA's Avatar
Brake lines. In particular the ones coming out of the ABS box and running to the res. To clean/shiny them up can I just hit them with some rubbing/polish compound by hand or is that a dremel needed job?
Old Nov 21, 2011 | 07:04 PM
  #508
LE35thSS's Avatar
what's the absolute best way to dry off a car after wash to avoid streaks/spots/etc...?
Old Nov 21, 2011 | 07:33 PM
  #509
02ws.sik's Avatar
Imo mf cloth thats all i use. It is soft and wont take of wax
Old Nov 21, 2011 | 07:34 PM
  #510
02ws.sik's Avatar
Dont know if this is a question for here or not so sorry if it isn't. What is the best way to clean then paint calipers?
Old Nov 22, 2011 | 08:46 AM
  #511
ThirdgenTa's Avatar
If you have wax on the car, do this. When you are done washing, remove the nozzle from the hose. Start from the top and work your way down "flooding" the car. Basically the water will sheet off and dry itself. I then go around the car with a leaf blower and blow the rest off and also get in the crevices like the trim, grill and mirror so that it doesn't leak out and leave water spots.
Basically it looks like this
http://www.youtube.com/watch?v=gCeyTHyFbck
Microfibers WILL swirl up a car so the less you have to actually tough the car, the better.
If you still want to go the microfiber route I would purchase high quality ones like COBRA so that it will swirl up less. The microfibers from the auto parts stores are cheap and will turn your car into swirl city in no time.
Old Nov 22, 2011 | 09:31 AM
  #512
I've been following the same drying method for the past few weeks, with very solid results. My wife thought I was crazy when she saw me get the leafblower out to dry my WS6 though.
Just this past weekend I rinsed, foamed, rinsed, foam washed, dried, clayed, foam washed, dried, iron-x, clayed. Didn't even have a chance to correct it because I took so long doing surface prep. Can't wait to get the paint corrected and have some nice deep gloss this weekend!
Old Nov 22, 2011 | 10:04 AM
  #513
dabest09's Avatar
Originally Posted by camaroboy14
Ok go fast I got some questions for you recently I started a business on base for simple car detailing now I am based in Germany so all I have access to is basic car care stuff and home cleaners at the market..brands they have out here are meguires, turtle, armoall , rain x , ect nothing fancy.. And I have access to home cleaners ..so I need advice for stuff that I don't have to use to much of, and that saves some money but works great. The list of stuff I clean is coming , along with what's the toughest parts to clean for me !
1)exterior paint(i hand wash, and spray wax) what's best?
2)wheels and tires(alot of heavy rain here so wheels are bad)
3)wheel wells(alot of grim and bugs)
4)engine bay(I need this part to be semi spotless with basic stuff)
5)windows(I use invisible glass)
6)interior(leather, plastic interior)
7)front end of the car(covered with flys and bugs thick amounts that are tough)!
Note I do this all at a hand car wash station, I bring my own bucket and supplies and do a vacuum too , so I need to know what products I can use/methods of using to make my life easier and make my clients happy ..oh and that save time thanks in advance I hope to hear from you !!!
Start at page 1 and read through this entire thread.
Old Nov 22, 2011 | 11:40 AM
  #514
WhiteKnight '01's Avatar
What's the best way to get rid of swirl marks?
Should I just take it to a professional detailer? I don't have a buffer, or a pad, or any of that.
Old Nov 22, 2011 | 12:01 PM
  #515
BadCompany VP WS6's Avatar
Using the MF's improperly will definitely swirl your car up just like anything else. ANYTIME you touch your car with any kind of medium you have the possibility of marring the finish. Using a quality MF with at least some sort of lubricity (detail spray etc) is a must. I never touch my paint with a dry MF and I've never had swirls show up from that. There is a science to all this so to speak, you just have to implement it.
Old Nov 23, 2011 | 03:01 PM
  #516
why87's Avatar
GoFast, I was curious on your opinion on what I should use to wash my car with (soap, equipment). I live outside of city limits and my water has a TON of minerals in it. It doesn't matter how i wash or dry it, I always end up with nasty hard water spots. This forces me to take the car to the coin operated washes (YUCK) just so it looks halfway decent. Any suggestions??
Old Nov 23, 2011 | 04:56 PM
  #517
GoFast908Z's Avatar
I wouldn't advise applying the 303 to surfaces you'll be touching regularly.
Detail spray doesn't have to be expensive at all. Look into Optimum No Rinse and Meguiars Last Touch (both on autogeek). It won't cut grease though.
Old Nov 23, 2011 | 05:05 PM
  #518
GoFast908Z's Avatar
Never tried polishing them, so not sure on that one.
Here's my thoughts.
#1 choice: QUALITY MF towels. Use one to soak up the water, and one to dry. Just keep wringing out the first one. This is my preferred method.
#2 choice: Electric Leaf blower. Works great, but has to be done right. The ground needs to be very wet under and around the car to keep ground dirt from getting blown onto the car. I would even recommend the motorcycle blower...can't remember what its called, but its basically a smaller leaf blower with a flexible hose and smaller end so its better for being precise. And you don't have to worry about hitting the car with the long leaf blower.
#3 choice: Absorber. Works well. MUST be kept perfectly clean. If you get dirt in it, there is no real nap for it to go into (like an MF towel), so it will scratch quickly and fiercely.
A good wheel cleaner will do. Or an all-purpose cleaner in a pinch. I'd recommend Sonax Full Effect or P21S Wheel Gel. Get some small brushes, toothbrushes work well, Swissvax wheel brush is a great addition.
Old Nov 23, 2011 | 05:15 PM
  #519
GoFast908Z's Avatar
Disagree on the MF part. QUALITY ones will not swirl up the car when used properly. I can wipe down a jet black bmw (just about softest paint out there) with microfibers without causing marring.
Old Nov 23, 2011 | 05:20 PM
  #520
GoFast908Z's Avatar
Read through the thread, I believe all those questions have been answered.
It may be a good idea to take it to a professional. If you want to take it on yourself, read through this thread it will be able to help you.
