My 6LE seat review of ownership
Old 10-31-2011, 01:55 PM
ssteven's Avatar
Default My 6LE seat review of ownership
Decided to rotate my black leather seats today. I've had them in my car for approximately 2 years. So far they have held up nicely. A very minor rub marks on the driver side and the back part by the harness holes came loose(easy 1 min spray adhesive and tuck back in) The cushions are stil firm. Only thing I dont like is the underside of the foam. it sheds small pieces of foam dust. So on a scale of 1-10 I rate them a 9 so far. Since i rotated them the formerly passenger seat is now my drivers- its a bit firmer since its never sat in much. Gave a nice leather treatment and they look brand new.
Old 10-31-2011, 02:30 PM
ZeeSNuttS's Avatar
Not a bad rating since are OEM seats are a 7 out of 10 new lol Mark makes nice stuff and alot of it is better then oem IMO.
Pix plz sir of your seats.
Old 10-31-2011, 02:36 PM
Formally Simplɘ Jack
BoricuaHec01's Avatar
We could rotate our oem seats?
Old 10-31-2011, 02:49 PM
ssteven's Avatar
I didnt think you can rotate OEM stock seats, never tried actually.
Old 10-31-2011, 04:03 PM
my bandit's Avatar
by rotating your seat, did your lever for the back recline change to the center console side?
Old 10-31-2011, 04:19 PM
ssteven's Avatar
The 6le seats have ***** on both sides of the seat. The slide adjuster is also the same.
Old 10-31-2011, 05:16 PM
1quickTransAm's Avatar
^ Wow, that's convenient!
Old 10-31-2011, 05:33 PM
99'CajunFirehawk157's Avatar
And FWIW, Mark doesn't actually make them, lil ninjas overseas do...
Old 10-31-2011, 05:37 PM
ssteven's Avatar
Im gonna send a fruitcake for christmas to the little ninjas as a way of sayiing thanks.
Old 10-31-2011, 05:40 PM
Super-Bat's Avatar
Can you post a pic?
What about the recline lever?
Old 10-31-2011, 05:49 PM
ssteven's Avatar
will post pix in a bit after the bastards stop coming around for the free candy handouts...
Old 10-31-2011, 05:58 PM
ZexGX's Avatar
Originally Posted by Super-Bat
Can you post a pic?
Pretty sure the ones SSteven has only have twist *****, not levers.
Old 10-31-2011, 06:08 PM
ssteven's Avatar
Yep 2 twistys per seat
Old 10-31-2011, 06:49 PM
Ballinonabudget's Avatar
Love my racing seats... they are the one's in Mark's writeup about the seat brackets on his site. Just from a different company.I ended up getting both seats, leather with black suede inserts, for around $300 shipped. And they have held up great! One of the best improvements I have made to the car so far. They are way more comfortable, and with the extra side bolster support and racing harnesses it makes driving way more fun
I just wish they made direct bolt-in brackets for aftermarket seats that didn't cost as much as the damn seats! lol...
Old 11-01-2011, 07:57 AM
camaroboy14's Avatar
man this is good to hear..in the near future i am thinking of getting those seats..cant wait too see them pics
Old 11-01-2011, 11:41 AM
TORK?'s Avatar
Have you made any long distance trips with them over say, 300 miles?
I don't doubt they are great seats to racing and the twistys, but I am curious how they compare to the stock seats when on a road trip.
Old 11-01-2011, 11:52 AM
ssteven's Avatar
I drove from california to texas (1200 miles) and they were very comfortable.
Old 11-01-2011, 12:35 PM
Copy & Paste Moderator
VIP1's Avatar
I have cloth seats and they were easy to disassemble. Leather is probably similar.
The backs are different due to the placement of the flip mechanism.
The bottom of the driver and passenger seat are identical. The only change is to move a threaded clip from one side of the bottom seat frame to the other. In fact, my driver's bottom is actually the passenger one. The driver seat bottom frame on mine cracked so a friend of my fathers welded it back up, but in the mean time, I swapped seat bottoms so I could drive the car. When it came back, I used it to reassemble the passenger seat.
Since you're there, you'll notice that the central support for the cushion is a bunch of thin wires that cut into the cushion causing the seat bottom to sink over time. I made a flexible sheet to cover those wires to keep them from cutting into the foam. I had some metal screen material and aluminum foil tape so I combined it. I wrapped the screen material around the wires to make a flat surface then wrapped that with the foil tape. That created a flat smooth flexible metallic surface for the foam to sit on instead of the wires. Sorry, I didn't take pictures.
Some screws holding plastic covers over the track.
4 bolts hold the seat in the car.
Some screws holding plastic covers over the seat tilt mechanism
3+ bolts hold the seat back to the seat bottom.
4 bolts hold the track to the seat
Once you have the seat disassembled, you can pull the cover off the seat bottom. Its held in with two long plastic clips (around 8" long). One clip running along the front and one running along the back. They hold the cover on the frame. Get one clip off and the other comes off easy. After that, the frame can be pulled out of the cover and foam combination. The cover can also be removed from the foam by just pealing/pulling it off.
Old 11-01-2011, 04:00 PM
ssteven's Avatar
The inner twist **** is almost against the center console. You have a little wiggle room when mounting to the brackets. The outer one is easy to adjust. Pictures are muey grande
http://i280.photobucket.com/albums/k...8/100_0632.jpg
http://i280.photobucket.com/albums/k...8/100_0634.jpg
Front bracket:
http://i280.photobucket.com/albums/k...8/100_0635.jpg
Old 11-01-2011, 04:33 PM
TonesMaro99's Avatar
dam those seats look comfortable lol
Quick Reply: My 6LE seat review of ownership
