Autozone DIY window tint
Old 03-16-2016, 12:54 AM
Game ova's Avatar
Default Autozone DIY window tint
So, with summer coming I decided to get rid of the old fading tint. But due to spending quite a bit of money on my car recently, and to keep the wife off my back, i figured I would try my hand at tinting. After all, over the years I've watched guys tint various vehicles I've owned, and it looked fairly easy, trust me when i say IT'S NOT! Well, since mine already had tint, I had to scrape out off, which is an ABSOLUTE NIGHTMARE! Next, I made a trip to my local autozone to gather the materials. A word of advice...do NOT get the tint with the adhesive already applied. It is next to impossible to use, get the one that clings and is reusable. It certainly wasn't easy...but hey....gotta learn sometime!
Attached Thumbnails Autozone DIY window tint-20160315_131749.jpg   Autozone DIY window tint-20160314_144921.jpg
Old 03-16-2016, 02:52 AM
Daniel Richards's Avatar
yes, the static cling tint is easier to work with, but it's not suggested for OPPERABLE glass, like the doors since it is FAR to easy to peel the corners up. Also, the static cling tint is frankly GARBAGE when it comes to BLOCKING HEAT, I used it briefly on my T-tops and even with a 5% tint the inside of the tint was SIGNIFICANTLY hotter then the inside of the Gila Heat Shield 35% tint I applied to the doors, the Static cling stuff doesn't have the modern heat/UV blocking layer that you find in products like the Gila Heat Shield, also all the tint in the world isn't going to stop that car from getting hot in the summer, especially when we have such a LARGE untinted surface area like the windshield, this again is where the heat/UV blocking tints come in, you can get clear ones that still provide the heat/UV blocking layer that really makes the difference. having personal experience with both kinds of tint I cannot suggest wasting time with the static cling stuff if your goal is to actually stop the heat.
also regular tint is not "next to impossible to use", you just need the proper tools and a little practice, i've done my doors twice now (screwed up a little the first time and then the window stabilizers broke and scratched the tint so it needed redoing), watch several how-to videos on youtube, mix up some J&J and DISTILLED WATER in a sprayer and have a heat gun handy, are doors are actually fairly easy.
Old 03-16-2016, 03:27 AM
Game ova's Avatar
Ouch, didn't realize the cling type wasn't for inoperable windows. But really I just wanted to block the sun as much as I could, not so much the heat. And when I said next to impossible, I meant that the tint was really hard to handle. If it touched ANYTHING it was scrap. I can't recall the tint shop having the adhesive type of film. I've yet to roll my windows down, but I guess I'm in for a surprise once I do.....DOH!
Old 03-16-2016, 05:04 AM
JDEP162's Avatar
Yeah tinting is no fun, and it takes some practice for sure. I've done quite a few, but for the camaro I paid a shop. Well worth it.
Old 03-16-2016, 11:47 AM
1999nbmZ's Avatar
My old Camaro was done with the cling type tint, but they laid the seam all of the way below the trim on the door panel. That kept the bottom edge from having any problems.
I also did not have any issues with the upper edge, but after reading Daniel Richards post, it sounds like I just got lucky.
Old 03-16-2016, 11:49 AM
themealonwheels's Avatar
If you absolutely insist on doing a portion of the tinting yourself, get some of the precut tint from eBay. I take the door panel off so I can thoroughly clean everything, then install one side at a time just peeling off of the precut sheet. Much easier, and looks great.
As for the rear window, I always get it tinted by a local shop. The shop told me last time how the rear window in these things have two opposing curves: the sides curve in, the bottom of the window curves out. This makes it very difficult and should be done by a pro. He did it while I watched, it looked like he was tearing it in small spots to get the film to stretch around the curves. Did it in one piece, very impressive!
But yea, the sides were like $25 shipped for 3M film.
Old 03-16-2016, 12:35 PM
ANY professional tint shop is using tint with adhesive on it, this is how "real" tint works, you do have to be careful it, but the water/j&j baby shampoo mix allows you to position the tint without the adhesive setting and if you cut the tint to the shape of the window (by laying it on the outside of the glass) before you remove the backing that exposes the adhesive it is yet even easier to work with, like I said, go watch some youtube videos and get the right tools and practice, you may never get the skill to do the back glass with all it's curves and angles, but the doors aren't to hard, heck you can even buy pre-cut tint off of ebay to do the doors, altho the fit isn't perfect, it's pretty close and most wouldn't notice.
I would say so, the bottom is less of the issue then the top, provided you take it low enough to start with, what I ran into with the static cling on the t-tops was I ran it out over some of the black surface (maybe that effected it's clinging capacity), so it went over the weatherstripping and in a summer (or less) the area around the weatherstripping had shriveled up real bad and it was falling off the t-tops when I took them out.
another thing I noticed, the cling tint was thicker and not as clear (it kinda blurred things), I was much happier with the Heat Shield tint even if the brand is not well liked by installers.
Old 03-16-2016, 01:57 PM
Game ova's Avatar
Well guys, I rolled the passenger side window down a bit, just to see if I got fortunate.......no dice ��
Old 03-16-2016, 04:07 PM
Tipnitty's Avatar
Yeah, no way in hell I would try to tint myself. I've heard of no one that was able to do this successfully from store bought tint.
Old 03-16-2016, 08:55 PM
JDEP162's Avatar
Yeah I've done normal windows a lot with it, squeegee and patience, let it dry for 3 days, good to go. But as above f-body windows are compound curves, let the pros do it with a clean room bigger tint and heats guns.
Old 03-16-2016, 08:56 PM
Rebob5's Avatar
I went with the ebay special pre cut tint on my car about 5 years ago and it still looks good and hasn't faded... not bad for $20. I do lots of vinyl graphics so i have some experience with large decals and the best advice is lots of application fluid. I used a spray bottle filled with water and a couple of drops of johnson & johnson baby soap and sprayed the glass and the tint like crazy with the solution. I also removed the hatch and flipped it upside down and installed the large 1 piece tint that way.... in the car would be impossible. Once you get it applied and where you want it you squeegee the liquid out from behind it and let it sit a few days and you should be good to go!!!
Old 03-16-2016, 09:51 PM
Get a Blue MAX squeegee and you don't need to wait days, it gets out a lot more of the water then the cheaper squeegee's that come in the kits from the parts stores.
Old 03-16-2016, 11:29 PM
dabest09's Avatar
Been there done that. With the big curves on f-body windows makes for a bad experience without a heat gun and/or experience tinting automotive windows.
Old 03-17-2016, 01:06 AM
Game ova's Avatar
Wife wasn't too jazzed when she seen her hairdryer as my heatgun.......
Old 03-17-2016, 02:28 AM
t_raven's Avatar
I buy rolls of pro quality tint of ebay. I'm not great at it, but I've successfully done a couple cars. I need more practice but for the cost of paying to have a car tinted you can buy enough tint to get a lot of practice.
If I only owned a car or two, I wouldn't bother with it, but with 15 or 16 I plan to hang on to for a while, it's worth learning to do it myself.
The side glass on my 01 TA came out good. I need to redo the hatch. That's a big piece of tint lol. I think I ended up using 3 pieces to get it all to lay flat, but you can see where they but together. I've seen people claim they can do a 4th gen hatch with 1 piece and no shrinking. It seems impossible but I'll have to try it again.
Old 04-26-2016, 06:39 PM
rpturbo's Avatar
1 pc and no shrinking? I don't believe that. I used to tint, and film has changed a lot over the years, but shrinking is where it has gotten better. The rear window on a Fbody, is a bitch, period, at least to make it look seamless.
Old 04-27-2016, 12:55 AM
Zlow28's Avatar
I took my rear window to get tinted and the guy told me he might have to use two pieces for the rear window. Luckily he only used one tho. I had to remove the side tint, but ill probably give it a shot this time around.
Quick Reply: Autozone DIY window tint
