Removing stress cracks
Old Sep 25, 2005 | 05:04 PM
GAME OVER's Avatar
Default Removing stress cracks
My car got bumped in a parking lot by another car and it appears to be stress cracks underneath the clear coat. I tried buffing by hand and have had no luck, anything thatll work?
Old Sep 25, 2005 | 05:13 PM
gavspurplez's Avatar
re-paint
Old Sep 25, 2005 | 05:17 PM
GAME OVER's Avatar
god dman it, it was just painted like a month ago!!!
Old Sep 25, 2005 | 06:42 PM
Onyx Z's Avatar
Stress cracks are just that, CRACKS. The entire layer of paint has cracked, which means a repaint is needed.
Old Sep 26, 2005 | 03:37 AM
BrandonSS's Avatar
Yup.. repaint. Make sure whoever does it takes it ALL the way down to plastic, or else its going to come back very shortly. Dupont, among others, has a flexible clear made for plastic exterior parts such as bumpers and our fenders.
Old Sep 26, 2005 | 09:31 AM
jargan04's Avatar
Most shops use flex agents, but it only helps so much. If something hats hard enough it will crack the paint no matter what. The shop I work for always used flex agent with our PPG paint on plastic parts like bumpers.
Old Sep 26, 2005 | 12:33 PM
94strokedz's Avatar
You can minimize and very near hide the cracks by wet sanding and then wheeling them until you get the shine you had before. Mine was bumped, cracked pretty bad. I did this, and now the only time I can see them is right after waxing when the cracks are filled with wax. After power washing the excess out of the cracks, you can barely see them. The only thing noticed up close is the clear coat is sanded off where ever high spots along the cracks were, but most do not notice. It will look like new from 3 feet away if you do this, assuming no paint flaked off of your car.
Old Sep 26, 2005 | 12:48 PM
parbreak's Avatar
I always use a flex agent called Bulldog. Pretty cool product because not only is it a flex additive, it's also a tie coat and adhesion promoter.
Bryan
parbreak
