what is the best way to smooth out a stock intake to paint it
Old 10-18-2005, 04:03 PM
black98's Avatar
Default what is the best way to smooth out a stock intake to paint it
need help and also some pic's would help! thanks
Old 10-18-2005, 04:08 PM
Xsta Z 28's Avatar
I sanded mine with a Black and Decker Mouse. Time consuming but worth it!
Old 10-18-2005, 04:25 PM
Mark IXZD 150's Avatar
Mouse sander.
Old 10-18-2005, 05:25 PM
1QUIKWS6's Avatar
Ditto here for the mouse sander + some good ole' hand sanding thrown in for xtra measure
Old 10-18-2005, 05:48 PM
VSGLS1's Avatar
I hand sanded mine because I was bored around the shop one night. Also used a scott brite pad.
Old 10-18-2005, 09:24 PM
ArcticZ28's Avatar
And what grit sandpaper?
Old 10-18-2005, 09:52 PM
VSGLS1's Avatar
I believe it was 320-600.
Old 10-18-2005, 10:32 PM
stryker14's Avatar
spray a high build primer and sand with 600 grit and you can get it smooth as a babies butt
Old 10-18-2005, 10:40 PM
ArcticZ28's Avatar
In that order?
Old 10-18-2005, 10:44 PM
stryker14's Avatar
Originally Posted by ArcticZ28
In that order?
actually I will scuff with a scotch pad, clean with a wax and grease remover really well, spray an adehsion promoter, then spray the high build primer. Once the primer is nice and dry I will wet sand with 600 grit and then I am ready for paint.
Old 10-18-2005, 11:18 PM
67RSCamaroVette's Avatar
I sanded off the casting marks with 80 grit, then used 180 on all of the tubes. I then sprayed it with high build primer,
sanded it with around 300 until it was really smooth, then sprayed it with a black poly primer with a hardener.
Wet sanded that with 600, then sprayed 2 coats of basecoat, then 3 of clear. I like how it turned out..
You dont need to do the black poly primer i think, but the store i bought it from said it was more heat resistant.
thought id put in a few... be sure to take your time.
olly
Old 10-19-2005, 03:12 PM
black98's Avatar
any more pics
Old 10-19-2005, 05:12 PM
99zee's Avatar
Brett, will you quit posting that picture That is the perfect match for my FRC's and lid.
Old 10-19-2005, 06:24 PM
stryker14's Avatar
Lol, I will try to refrain...or at least put a warning for you to not look
Quick Reply: what is the best way to smooth out a stock intake to paint it
