Arizen Racing Sports Custom Leather Seats!
Just wanted to post some pictures of a new leather seat pattern we did at a customers request. The inserts match the o/e pattern of his Camaro. We will be adding the seat belt guides tomorrow. This color is Ebony but we can do other o/e colors as well.
If you have a different car with a different pattern you would like a quote on emails us with the specifics. Include year, make, model and o/e leather color and a picture of the original seats in your car or a similar car.
If you would like a custom color/material combination that is not already present in your car we may be able to make a rear cover as well in the colors/materials you desire.
Originally Posted by Thule
wow.. how much are those?
Originally Posted by 1998Z28LOADED
... and measurements... and can you do white?
I'm not sure about an o/e white. I'd need the exact year and model to inquire if it was a factory option.
Originally Posted by arizen
Of course, you can still have the harness slot in the headrest if desired. We can install heaters from a GM licensed supplier as well!
Originally Posted by ZMONSTER!
Awesome seats! do you have the same pattern for the rear seat covers as well? naturally in ebony leather.
Originally Posted by BitViper
Mark....what i steh MAX width of your seats..including the backrest adjustment *****?
It would be tight. It is 21" across the reclining *****. We can remove the inside **** and reduce it about an inch but the bolsters are then a little wider than the **** area. I'm not sure if that ok because the bolsters are raised somewhat.
Originally Posted by PhillyLS1
How much do they weigh in comparison with a stock seat?
