all my gauges are screwed up!!!
![Exclamation](https://ls1tech.com/forums/images/icons/icon4.gif)
ok so i put the macawen white overlays in my car well i did everything as the instructions freaking said and now my tach needle has trouble moving past 4,000 rpms and the speedo has a tough time moving past 40mph anyone else had a similar problem like this. what can i do to fix it? a friend of mine said to get it recalibrated but where the stealership???
You didn't remove the needles did you? With my Macawen's the needles did not have to be removed. Check the needles to make sure they are not in a bind or hung up on something from behind. Shouldn't need any recalibration, nothing changed but the background.
i did what the instructions said the 4 at the bottom are fine and i removed them and i DID NOT touch the tach or speedo and they ARE the ones that are screwed up
hmm i dunno then. i do not remember the inst. saying to remove the bottom needles if need be
speed limit most places is 40mph anyways so STOP BREAKING THE LAW, *******!
jk, seriously though try loosening the needles or removing / reinstalling them and see if that helps?
if you are having trouble thuogh puttin a sticker on though you might wanna take it to a shop.
