VFN Hood Fitment Instructions?
Old 05-31-2008, 06:23 PM
hashtagBMW
Speed Density's Avatar
Default VFN Hood Fitment Instructions?
Anyone got the paper that comes with the hoods to tell you how to go about getting everything all lined up?
Spent about an hour today working on my 3.5" SS hood, ive got about 1/2 gap on each side near the fenders that id like to clean up.
Tony.
Old 05-31-2008, 06:33 PM
phantomzer0's Avatar
I don't have the paper but I have a little guide that I made.
http://armorysound.com/forumsadv/sho...32&postcount=1
I hope that kind of helps out. The biggest thing that needs to be done, is the hinges. You HAVE to notch them out. Just get a drill and drill out your holes to be a tad bit larger.
Old 05-31-2008, 06:36 PM
hashtagBMW
Notch the brackets eh?
I keep trying to 'stretch' the hood, lol. I want it to cover more space that I think it ultimatley will.
I need mine to go left/right, the fitment near the bumper and cowl are awesome..
Tony.
Old 05-31-2008, 09:19 PM
6LITEREATER's Avatar
Tony.
You can pull your fenders in some... On a Camaro at least, there are L-Shaped brackets moutning the fender to the support at the front. You can loosed the horizontal bolt (10MM), push the fender in and tighten the bolt down to get rid of gap and the front of the sides...
Old 06-01-2008, 12:09 AM
renzos23's Avatar
everything sits well with hood but the corners near the glass stand up a lil. is that normal?
Old 06-01-2008, 12:18 AM
It could be depending on how bad it is. Usually aftermarket hoods fit weird a little bit in some specific places. I've seen sunoco hoods fit perfectly before though, so I'd say that you could probably go in there and lower the corners a bit. You really have to get in there and play with the brackets.
Old 06-01-2008, 01:08 AM
Mine sits a LITTLE high in one of the corners near the glass as well but I haven't played with the brackets... Not bad enough to care...
Old 06-01-2008, 03:15 AM
hashtagBMW
So the brackets are inside the fender? A little lost on the statement.
Overall im happy with the fitment, i can stick my fingers in the sides, but other then that for a fiberglass hood its great.
Tony.
Old 06-01-2008, 03:35 AM
Tony.
No, I am talking about the brackets I circled for you in this pic:
Old 06-01-2008, 12:47 PM
djsanchez2's Avatar
Just got my Sunoco hood and the rear sits a lil high too. Also the front sits perfect, w/ the exception of the center where the latch pulls it down so it does not sit flush with the nose. I need to add a spacer under the latch or ring. Guess i'll have to notch the hinges too and i'm set. All the gaps are fine though, I'm pleased with the quality of this hood overall.
Old 06-01-2008, 02:22 PM
hashtagBMW
LT1's dont have those clips.
Old 06-01-2008, 03:04 PM
Where is the front of the fender held to the radiator support then?
Old 06-01-2008, 03:08 PM
Around the headlight bar maybe?
Old 06-01-2008, 04:58 PM
hashtagBMW
The radiator support goes up under the fender somewhat. I have bolts going all the way up the fender towards the cowl.
Ideas?
Old 06-01-2008, 07:38 PM
hashtagBMW
Drivers side near cowl
Passanger side near cowl
Drivers side fender
Drivers side cowl
Drivers side fender
Passanger side fender (worst)
Overall
Old 06-02-2008, 10:55 AM
vfntech's Avatar
Seen your pm and noticed these pics - looks like you need to drop your hood down a bit by lowering the hinges, I know it seems like the gap won't close, but once the hood is lowered it'll close these gaps up nicely.
Old 06-02-2008, 12:00 PM
SSquid's Avatar
GOD! thats a thick hood! what if he shaved the undersides a bit? cause the way it looks... looks like the hood might be hitting
SSquid's Avatar
Not hijacking the thread... but are all their hoods that thick?
Old 06-03-2008, 12:24 AM
99z28monster's Avatar
Sorry to jack your thread but how do you lower the hinges? I am having a crazy time getting my sunoco from VFN to lower on the corners near the windshield.
Old 06-03-2008, 01:13 AM
Using a Dremel or drill bit you enlarge or elongate the holes to give you some adjustment room...
Quick Reply: VFN Hood Fitment Instructions?
