Atf
Old Jan 6, 2009 | 05:19 PM
2002 Trans Am's Avatar
Default Atf
Which one for a 4L60E
Can't believe I can't find it in the FAQ and search is down
Old Jan 6, 2009 | 05:48 PM
joecar's Avatar
Dexron III.
Old Jan 6, 2009 | 07:37 PM
Originally Posted by joecar
Dexron III.
Thanks
Old Jan 6, 2009 | 08:32 PM
tptransmission's Avatar
Closed ex-Sponsor Account
Dex VI will work also.
Old Jan 6, 2009 | 10:52 PM
crmartin99's Avatar
and dex vi is twice as good... ok, bad joke.
Old Jan 6, 2009 | 11:22 PM
the_merv's Avatar
IV is four.
Old Jan 7, 2009 | 12:09 AM
9000th01ss's Avatar
Originally Posted by the_merv
IV is four.
I don't think they made a Dexron 4. They went from 3 to 6.
Old Jan 7, 2009 | 12:49 AM
the_merv's Avatar
I thought it was Dexron 4, never heard of 6, seriously..lol
Old Jan 7, 2009 | 01:38 AM
9000th01ss's Avatar
Dexron for some reason went from III to VI
There is also an ATF+4 but it's not Dexron.
I forgot the reason for no IV
Old Jan 7, 2009 | 02:23 AM
the_merv's Avatar
That's what I'm thinking of probably, the +4 stuff.
Old Jan 7, 2009 | 10:19 AM
TXZ28LS1's Avatar
i just stick with DEX III
Old Jan 7, 2009 | 10:48 AM
Chrome355z's Avatar
This will go in my next trans oil drop (or may wait till I toast the stock tranny and get a built one). It's costly though.
Allison Transmission TranSynd
http://www.allisontransmission.com/c...Aug2001/88.jsp
Old Jan 7, 2009 | 11:08 AM
9000th01ss's Avatar
Heres the 2009 version.
Old Jan 7, 2009 | 11:24 AM
Allison is now using Dex VI. Dexron VI was development specifically for the GM 6 speed.
Old Jan 7, 2009 | 11:49 AM
Chrome355z's Avatar
Be careful there, only the Allison 1000 series was designed in a codeal with GM Powertrain so they ended up having to use GMs specs for oil and shipped with DexVI iirc. GM can mfg and call it an Allison as long as they don't make a design change.
Allison Transmission uses TranSynd in the Medium/Heavy Duty Transmissions that they manufacture to this day. DexVI would VOID the warranty on these transmissions, and circa I believe 2006 it would cause physical problems due to seal compatibility issues.
I'll be at Allison in the next month or two to talk to their oil guy, i'll se what more info I can find out!!!
Old Jan 7, 2009 | 12:22 PM
TranSynd is a better fluid if you want to pay for it. I was Just pointing out that some Allisons did go to Dex 6.
