Archor vs. stock tranny mount
Thanks
https://ls1tech.com/forums/automatic...yone-used.html
https://ls1tech.com/forums/automatic...ans-mount.html
https://ls1tech.com/forums/automatic...nny-mount.html
https://ls1tech.com/forums/automatic...different.html
https://ls1tech.com/forums/automatic...on-mounts.html
The search feature NEVER works when you mis-spell words.
As far as height difference if it moves the TA up with the trans it could change the pinion angle. If it moves the trans up it will change the u joint operating angle.
All this can lead to a high speed vibration.
If the mount is taller, add spacers between the cross member and frame to lower it to where it was.
I make mistakes and am not perfect, just looking for some help from those with knowledge.
The one from Thunder is a Delphi mount and is about !/4" taller, is this enough to mess up the angles and maybe should not use it?
I have not used the Anchor, I bought it after breaking the stock mount, and now have the ES poly trans mount and poly engine mounts, so to help with the vibration I thought I could go back to a rubber trans mount and I have the Anchor and the new Delphi to choose from, guess I could get another stock and not worry about breaking it because of the poly engine mounts, but they are $$$.
Or get the stock one.
Are you sure it's the trans mount?
I have poly engine mounts with the stock trans mount, it has a vibration. I don't plan to do anything about it.
The only thing I've run in an F-Body is the poly engine mount, stock trans mount.
In other cars I've run solid everything, in my truck I have stock engine mounts, poly trans mount (found a new one in the package at a junkyard)
It depends on your tolerance to vibration also.
Good luck.
