4L80, from 4WD to 2WD, what do I need?
Hi guys, I just bought a 6L truck engine with a 4L80 atached to it.
It is 4x4, so what parts do I need to buy to make it 4x2?
Who sell those parts? And who sell them used?
Its for a budget project.
Thanks for any help.
Closed ex-Sponsor Account
There is a ring on the output carrier, just no sensor. They use the sensor in the T-case. It is not a difficult conversion just a output shaft and case extension plus the orifice in rear plug.
For the swap you need these 4x2 parts:
Output shaft
Tail housing
Speed sensor reluctor wheel
Rear speed sensor
Orificed cup plug
Maybe valve body gaskets, I would get a whole paper and rubber kit (usually comes with the cup plug).
Probably around $400 worth of parts depending on where you get them.
4x4's DO NOT come with a reluctor wheel for the rear speed sensor.
Output shaft
Tail housing
Rear speed sensor
Orificed cup plug
Output shaft
Tail housing
Rear speed sensor
Orificed cup plug
Thanks for the info. I am chacking at ebay.
