B&M Super cooler guys (with fans)..I need help
Okay im wanting to use this cooler
http://www.summitracing.com/parts/BM...5&autoview=sku
But I need to know what I need to mate this cooler to my transmission.
I have a list of fittings here but im not sure about hose sizes or anything..can someone help me out?
http://www.summitracing.com/search/P...pter-Fittings/
My guess would be it will come with fittings. You can put together a setup cheaper then that. I bought just an oil cooler and a fan separate. Then just went to local harware store and got fittings to go from 1/2" NPT to 3/8 hose.
http://www.summitracing.com/parts/PRM-19127/
http://www.summitracing.com/parts/BMM-70273/
The fan in the kit your looking at is only 590 cfm. Fan I linked you to is 1800 cfm.
Heres mine...
Heres mine...
heres a site that might help you out-i am using a B & M cooler w/o the fan, mounted under the car at an angle, never gets over 160
http://www.purechoicemotorsports.com...cat/cat135.htm
i was thinking exactly the same thing as a read the tread should i put the fan on my dopestyle cooler blowing up or down to the floor?
i think the cooler i used was #70274, had the 1/2" npt in/out
i would think you want the fan blowing in the direction of air flow when your moving, so your not fighting against it-is the fan used just when your sitting still, or is it for when the cooler is in a remote location with no air flow, i have never used one with a fan
i couldnt mount mine in front of the rad. due to the intercooler, so thats why i mounted it underneath, but at a little bit of angle, figured air would hit it better-prob your body style it wouldnt work
This is how I mounted mine. I'd give you some better pics, but my car is gone. It's mounted just above the air dam, angled forward in front of the radiator. I am also still running through the factory cooler in the radiator. No problems keeping it cool this way.
When mounting a fan unit dope style the fan would need to push or pull the air upward as this is the natural way the air flows into the radiator.
If your heard it run, you might think different. Thing sounds like a damn blow drier when its on.
