Driveshaft is shafting my project!
So i was attempting to put my car back together, and the slip yoke won't go all the way into the trans. I can't get the U-joints in the rearend. It is a stage 7 FLT trans just rebuilt no miles on it. The rear-end is a dana s60 with a custom driveshaft made to proper length. Now when i took it apart everything fit together as it should.
The driveshaft was tough to take out when I removed it the first time, but it came out with a little love. It is basically like the only hang up on this project so far and it is so frustrating because it fit together when I took it apart. What I am asking is does any have any input or ideas as to why I can't get this driveshaft in!
Maybe the new ext housing bushing is a little tight.
The only answer really is to take the ext housing off and see what you have there, then look at the yoke. You'll find the problem quicker that way rather than just trying to shove it in and giving up.
I am not really sure what is going on with damn thing, I called FLT today and they have said they have seen this issue before but i don't want to buy a new yoke.
The yoke goes into the trans about 2 3/4 of an inch, and the yoke itself is about 4inches long. Does anyone know how far the yoke should go into the trans on 4L60E?
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
