Circle D converter (the cheaper one)
"The 278mm is a great option for DDs, and sounds like a might be a good match for you. It will leave a little on the table for performance, but still much better than the OE converter and the dead spots. I rate it to handle ~450 to the tires, so you should be good there. "
What ultimately sold me on the full billet converters was the options you have. For one its a completely CNC'd unit with lots of modifications you cant make to a stock converter. Plus, you have more control over the balance between performance and drivability.
If you never plan to race and just want to step up the street performance then the Circle D 278mm is a good option, but if you plan to compete (street or strip) then the Circle D custom billet 245mm converter will pay you back in the long run and the track results prove it.
G/L
713-895-8834
Chris
Also I was planning on running this with my stock tranny...if I was to go with the expensive circle d stall would it be able to be cleaned and reused after my stock tranny dies?
