Ever wonder why a Stalled Auto will out run the M6
Old 08-31-2010, 08:29 AM
Yank's Avatar
Default Ever wonder why a Stalled Auto will out run the M6
The Stalled Auto will put more power to the ground that the M6 car
in this test two stock GXP LS3 cars are compared.
As you can see the stalled car with either the SS3200 or the SS3600 put down more HP to the wheels and did this almost thru the complete RPM range.
The cars are both run in 3rd gear with the A6 having theconverter unlocked as you can see the A6 has a higher MPH range and the M6 will have a shift at 89 MPH to keep up with the A6 to 99
MPH. In addition the M6 was at a disadvantage in the low MPH range below 35 MPH, this allows the A6 to out run the M6 from the lower MPH start point to red line.
https://ls1tech.com/forums/attachmen...e-scan0005.jpg
Old 09-01-2010, 03:39 AM
rsz288's Avatar
The cars are both run in 3rd gear as you can see the A6 has a higher MPH range and the M6 will have a shift at 89 MPH to keep up with the A6 to 99
How do the higher stall convertors compare to the factory convertor?
Old 09-01-2010, 08:18 AM
Yank's Avatar
Look on our site www.converter.cc at the dyno test area and see a stock converter to SS3600 test the SS3200 will be up soon
Old 09-01-2010, 09:06 PM
rsz288's Avatar
There doesnt seem to be a dyno test link. Though may be I am simply blind today .
Old 09-02-2010, 05:41 AM
Yank's Avatar
Use this one
http://www.converter.cc/g8/index.html
Old 09-02-2010, 11:54 AM
poorhousenext's Avatar
I'm trying to put a prospective on your testing.
G8 A6 3rd gear ratio I believe is 1.53
4.03; 2.36; 1.53; 1.15; 0.85; 0.67
G8 M6 3rd gear may be 1.30, at least that is what C6 corvette is.
C6: 2.66; 1.78; 1.30; 1.00; 0.74; 0.50
What is the rear end ratio of the G8 A6 equipped car and what is the rear end ratio of the G8 M6 equipped car?
Is rear gearing difference the reason the M6 has to shift in 1/4 mile?
What I'd rather see is graph comparison of time to rpm measured from 3400 rpm to same approximate rpm max HP is achieved by both cars.
I know from experience on my Motorcycles, that when I do WOT runs in 1.00 gear, Engine shows and increase of around 4-5 HP with 3.15 gear ratio over what it make when I swap over to 3.37 rear gearing.
But when I measure how long it takes the engine to rev to 6000 RPM from 2500 RPM, of course the 3.37 gearing produces a faster time. When checking MPH the 3.37 reaches the same MPH faster than the 3.15 does when checked at same time. So MPH hour wise, it shows a faster rate of climb than with the 3.15 rear gearing.
Not sure about which will win in 1/4 mile the G8 with A6 or G8 with M6. Maybe it's one of those things only a LONG BLACK DYNO can determine
By the way, I am running one of your TQ converters in my 1966 corvette LS7 & 6L80E build.
My other 64 corvette build, is being built to compete in Pro Touring events that only one of is straight line. How TC handles down shifts is as important as how it handles up shifts as engine needs to be kept in it's power band at all times.
I don't think a stall above 2400-2500 RPM works either when competing in Pro Tour events. Manuals due to gear splits seem to kick Auto's Butts in Pro Tour Events.
Time will only tell if car with it's 4L80E based 6 speed with it's gear splits is competitive with Manual Pro Tour Cars, and on Drag Strip with comparable HP to weight cars with either A4 or A6 transmission and their 1000 RPM higher stalled converters. Can my Gearing make me competive with them?
Old 09-02-2010, 01:08 PM
Yank's Avatar
M6 rear ratio 3.70 and the A6 rear is 3.27
Old 09-02-2010, 06:39 PM
Wicked94Z's Avatar
how much more apples to oranges can you get? this thread makes absolutely no sense.
Old 09-02-2010, 07:26 PM
Yank's Avatar
Look at the graph and see.
Two stock cars of the same make GM GXP LS3 2009 one with auto and one with M6 with no changes other than the converter added make sense?
The A6 car puts down more wheel Hp than the M6 thru out the full RPM range.
But with the stock converter it was lower in all ranges than the M6 the converter added a huge Hp increase to the ground!
this made a A6 car that could not keep up with the M6 kick it"s ***
Old 09-02-2010, 08:04 PM
rsz288's Avatar
LOL. There it was staring me right in the face wasnt it! Having a blind day . Thx.
VERY impressive results. Your convertor designs obviously do as you promise and that is getting the engine rpm up and the resulting power across without turning the speed differential across the fluid coupling mostly into heat. Very efficient.
Major increase in area under the curve which is where the great results come from.
Was Patrick G's tune on the engine only or engine and trans?
Old 09-02-2010, 08:19 PM
SAPS's Avatar
So now a stall converter can magically offset the inherent higher drive train loss in an auto???
Every dyno comparison I've ever seen, the M6 is a few % higher.
Old 09-03-2010, 07:39 AM
Yank's Avatar
In this test the tune was to the engine only!
but we did add the trans tune added and it made a great improvement in driveabilty.
Old 09-03-2010, 09:30 AM
Big_Bird_WS6's Avatar
ok so lets compare cheaper cars. like the fbody.
i have a stick and mine stock against a guy with a 3200 stall( his was stock i believe) i still raped him. i think this test has to many differences. the trany gears you cnat really change. but eh rear gears you can. so lets get a car with same rear gears and do a a few sets of dyno runs. then on the track.
you should take a new camaro and test it. the auot is rated at 400 and stick is rated at 430( somewhere around there) you put a stall in that auto. it wont pick up 30 horse.
there is way to many varibles. just need to start with a motor and 2 transmissions.
bolt up motor and M6 and hook that to a dyno and see what horse it has in all gears.
then bolt up Same motor and A6 and see what horse it has in all the gears.
that would the best way of doling this. you need a complete comparisen of all the gears. the auto might pul harder in first and the stick in second. so no real way to know a a 3rd gear pull when the dears are so far form each other on size
Old 09-03-2010, 10:10 AM
Yank's Avatar
Again this 3 gear test from a low speed roll to red line.
Two stock cars on the same Dyno the same day (cars are as produced by GM) the M6 car out horsepowered the A6 car in stock form.
But the A6 car out horsepowered the M6 car with only a converter change this is showing the power to the ground gained by adding converter.
The results are much the same in all cases the converter has an STR that extends out by design and this is shown in this testing format.
Old 09-03-2010, 03:19 PM
m1a2d3's Avatar
not to hijack the thread but when should you change the transmission fluid after stall install. i had a yank ss3600 put in my 2002 ss . about 500 miles ago.
Old 09-03-2010, 04:58 PM
Kevin01Z28's Avatar
Yea I dont get it.
Is this claimed 8.2 rwhp increase at peak rpm's with the custom tune on the SS3600, and a stock tune on the factory converter?? I would think to be fair you would want the same tune on both converters to eliminate that variable to test peak numbers. Otherwise that claimed hp increase could easily be attributed to the tune.
On the other hand I know that big converters shine at lower mph and will easily pull a car with a stock converter off the line or from a low roll, maybe even pull a M6 car down low, but not up top. I've ran a Circle-D 4C and a 2B, both 245mm. The 2B pulls harder at peak rpms. My stock converter pulled a little better than the 2B at peak.
Old 09-03-2010, 06:00 PM
Yank's Avatar
Originally Posted by Kevin01Z28
Yea I dont get it.
There was not a tune on the car with the 8.2 RWP increase the tune netted a bigger gain
Did you read the info on the graph sheets?
3 runs on the graph
Stock converter,SS3600 no tune, and SS3600 with tune
Old 09-03-2010, 06:27 PM
Kevin01Z28's Avatar
Actually no, I skipped to the bold at the bottom.
The automatic car had 14K miles. What about the stick? Did I miss that too?
Old 09-05-2010, 08:23 AM
Wicked94Z's Avatar
what about the graphs on the site touting high converter efficiency, and it was run with the converter LOCKED obviously its going to make power you're taking 30+ pounds of rotating mass away.
not bashing your product, im sure the converters are top notch. but the advertising confuses me... i'd like to see a rpm scaled graph as well as the torque curve, obviously its gonna show a buttload of torque (hp) down low over a stick car!
Old 09-06-2010, 12:54 PM
Yank's Avatar
M6 car had 16 K miles
Quick Reply: Ever wonder why a Stalled Auto will out run the M6
