tcc wont lock , will lock w/hpt scanner
Could I get some help with this one? My tcc wont lock at all. The engine is a 2000 camaro ls1 / 4l60e with the only modification is LS6 cam , valve springs , and compcams pushrods. There are no codes, and no missfires.
With the hptuners software it shows it is enabled and when I hit the brake the pcm disables it, so the brake switch is not the problem, but the pcm is not commanding any pwm to the converter solenoid. When I manually actuate it with the software, it locks up and works fine with no slip. This engine and trans has been installed in a very light (2875LB) vehicle. Below is a copy of everything modified from the stock calibation. All emissions stuff have been removed and all torque management disabled as well. Do you see anything wrong?
Main File : SEPT19 TRANS.hpt
Compare File: My2000CamLS1bin.hpt
Main File Parameters : 456
Compare File Parameters: 456
Parameters Compared: 452
Differences : 20
Similarities: 432
Engine
General
EGR
EGR Enable Disabled : Enabled
AIR Pump
Air Pump Disable Coolant Temp 254 : 14 °F
Spark Control
Spark Advance
Main Spark Advance
Main Spark vs. Airmass vs. RPM Open Throttle, Low Octane 578 of 725 cells
Transmission
Auto Shift Speed
Full Throttle Shift RPM
WOT Shift RPM vs. Shift - Normal 2 of 3 cells
WOT Shift RPM vs. Shift - Performance 2 of 3 cells
WOT Shift RPM vs. Shift - Hot 2 of 3 cells
WOT Shift Enable TPS 87 : 94 %
Auto Shift Properties
Desired Shift Time
Desired Shift Time vs. Torque - Normal 51 of 51 cells
Torque Management
Abuse Mode
Abuse Mode Master Enable Disabled : Enabled
Trans Abuse Mode Torque Reduction RPM 0 : 1200 rpm
Trans Abuse Mode Torque Reduction TPS 0 : 5 %
Trans Abuse Mode Torque Reduction Speed 0 : 255 mph
Trans Abuse Mode Torque Reduction vs. RPM 15 of 18 cells
Torque Reduction
Torque Reduction vs. Torque vs. Shift - Normal 19 of 51 cells
System
General
Security
VATS Control None : PWM
Fans
General
First Stage Fan Turn On Temp 226.0 : 226.4 °F
First Stage Fan Turn Off Temp 219.0 : 219.2 °F
Second Stage Fan Turn On Temp 234.0 : 233.6 °F
Second Stage Fan Turn Off Temp 227.0 : 227.3 °F
Speedometer
Speedometer
General
Final Drive Ratio 2.73 : 3.23
Differences : 20
Similarities: 432
Engine
General
EGR
AIR Pump
Spark Control
Spark Advance
Main Spark Advance
Transmission
Auto Shift Speed
Desired Shift Time
Torque Management
Abuse Mode
Torque Reduction
System
General
Security
Fans
General
Speedometer
Speedometer
General
Gingervitis Addict ![](http://s24.postimg.org/5ong4sl1t/Gingervitis2.jpg)
Differences : 20
Similarities: 432
Engine
General
EGR
AIR Pump
Spark Control
Spark Advance
Main Spark Advance
Transmission
Auto Shift Speed
Desired Shift Time
Torque Management
Abuse Mode
Torque Reduction
System
General
Security
Fans
General
Speedometer
Speedometer
General
Differences : 20
Similarities: 432
Engine
General
EGR
AIR Pump
Spark Control
Spark Advance
Main Spark Advance
Transmission
Auto Shift Speed
Desired Shift Time
Torque Management
Abuse Mode
Torque Reduction
System
General
Security
Fans
General
Speedometer
Speedometer
General
Moderator
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Misfires almost certainly.
Scan TCC_Mode and if you see -3- when it's misbehaving,
that says "I wanna, but..." which definitely points to
misfire holdoff.
Double your non-32000+ values in the misfire tables if
you can't see anything uneven in the Misfire Current
Cylinder 1-8 PIDs that points to a localized problem.
misfire holdoff.
Moderator
If you max them all you will fix this problem, but receive no
warning if something goes bad (like if a plug wire comes semi-
off, you could tell which cylinder by a quick scan for misfires).
Doubling the values is all it took for me to eliminate unlocking,
but keep gross-misfire detection.
Misfire detection is a useful diagnostic tool if you can just
make it quit bugging.
Ok so I maxed out eng diagnostics , misfire, low med and high rpm. Also maxed out cylinder mode tabs as well and still no overdrive.
I did notice when comparing my tune with the stock 2000 camaro file, that in the speedo calibration section, I have diffent tire sizes from fact. specs (3" shorter) and 2.73:1 gears instead of 3.23:1, but when I show differences only the only number that is different is the gear ratio. Mile, rev - trans, and trans revolutions/mile are the same as stock bin file. Could this be my problem?
Also on a separate note, if I just wanted to change the VSS pulses going to the gauge cluster but not mess up shift points and trans operation, what in speedometer section should I adjust?
Thanks in advance!
Thanks in advance!
Thanks for the info ,I got the speedo correct, maxed out all the missfire tables, still no tcc lock up . Locked it with the hPtuners scanner, but my laptop battery sucks and it kicked off before I could scan it . Also the torque converter is stock as well. Anymore ideas?
Here is the tune.
No P1870 codes, no codes at all . Some emissions codes are disabled. I'm new at this Hptuners scanner. I have to try to find out how to scan the tcc in further detail to check the TCC modes.
The file I attached was taken from the pcm that came with the LS1 eng. and trans. I bought. Year 2000 camaro 5.7L . The changes are listed in above post.
Thanks.
Thanks.
I'd put more mph between the tcc apply and release speed.
Other than that I might guess a tcc pwm solenoid mechanical failure, it would put out a dtc if it was a tcc pwm solenoid electrical malfunction. And I'm guessing when you lock it up with the VCM controls you do it by hitting the on button under TCC Solenoid which bypasses the pwm solenoid.
I just checked my stock Camaro ls1 bin with all the other binfiles for a stock 2000 camaro I could find online and not one matched it perfectly . Im going to try to copy one online, add my mods to it and see if it works. Maybe something went wrong when uploading or saving it .
Yes I will bump the mph for apply and release as well. FYI that is the way this calibration came from the factory. I will put 5-7mph spread in between them like all the other 2000 camaro bins I checked.
Here is the scan hptuners file I used to scan it, Im getting "TCC ramp exceeded" in pids is red and all others look ok . Does anyone know what that "TCC ramp exceeded" means?
