Variable Pitch Stator
Old Feb 15, 2012 | 07:52 PM
Mr. Sir's Avatar
Default Variable Pitch Stator
Does anyone have a diagram/cutaway showing how it works? Or know how it works?
Old Feb 15, 2012 | 08:01 PM
Fbodyjunkie06's Avatar
Not you again...
Old Feb 15, 2012 | 08:53 PM
slow67's Avatar
Gingervitis Addict
Your google skills must be failing you......
http://www.popularhotrodding.com/tec...ova/index.html
Old Feb 16, 2012 | 12:22 AM
Mr. Sir's Avatar
...That's great and all, but I've already seen that article, and used many different search engines trying to find out how it works. What I meant was a diagram of the internal workings of the stator (the pump as well, though it's probably a little easier to figure out if you find one). I want to know how the increase in oil pressure changed the angle of the blades, and how they fit everything in such a tight space.
Old Feb 16, 2012 | 07:44 AM
justin hover's Avatar
Why are you sooo interested in the anatomy of a stall? Just get a 3600 and be done with it.
Old Feb 16, 2012 | 12:33 PM
Mr. Sir's Avatar
For the most part, I like the stock manners of the car. However, I want higher stall, better efficiency, and no tire spinning. These 4 things don't all work together, so I have to play around with it. I like things to be right, not almost right. Once I get the money, my car will be right, even if I have to make everything myself (stall included).
Old Feb 16, 2012 | 03:58 PM
Yank's Avatar
I have all the parts needed.
special front pumps for TH400 and some S Pitch converters.
PM me if you want this stuff at a great price.
Old Feb 17, 2012 | 04:15 AM
So beef up your suspension, get some tires, tthheennn get your stall....High stall, better efficiency, stock manners, with little if any tire spinning. And if it is stock, shouldn't you be completing your exhaust first? Just over 2 years I've owned my car and I can say now it's ready for a stall.
 Michael S. Palmer
Old Feb 17, 2012 | 06:15 AM
Mr. Sir's Avatar
I'll probably do most everything at once. I plan on creating some sort of new interior, since god frowned upon the original. That + sound deadening + tires + engine + trans + rear + tuning all starts to add up, so it'll be awhile before I do anything. Not sure on suspension, I don't want it to be rough or lowered.
Old Feb 18, 2012 | 12:06 PM
chris718's Avatar
I have extensive knowledge of the VP setup.Give me a ring at the shop next week and I can give you a full explanation in 5 minutes.631 218 1048.
Old Feb 18, 2012 | 01:15 PM
Mr. Sir's Avatar
Sounds good, though I do have some simple questions:
How hard would modifying a 4l80e pump for variable pitch be?
How hard would modifying/creating a stator for a modern stall be?
What is the efficiecy of old vs new converters (given similar str)?
essentially, what would be the difficulty/expense of having OD + lockup + VPS?
And if the TH400 is the only way to go, how much converter efficiency (if any) is lost?
Old Feb 19, 2012 | 05:40 PM
chris718's Avatar
You are going to spend serious time and money on setting up a 4l80 pump and converter and input shaft to function as the original 400 vp parts did. If you have the funds to do it you can contract someone to build you a one of a kind set up.Im not getting into converter efficiency and STR,there are too many variables involved in this and even with a power output number and vehicle weight my guesses would be nothing more than predictions,as would anyone elses.If you want to know how the system works Ill give you 5 minutes of my time for an explanation.If you need any info other than that its not going to be free.
Old Feb 21, 2012 | 10:12 AM
jimmyblue's Avatar
Moderator
I doubt you're going to get variable pitch and lockup,
together. And lockup basically gives you the variable
that the low stop of the switch pitch gives you -
negligible highway slip - while the modern high stall
converters go better on stall speed and STR at the
other end, as well as being maybe 20 pounds lighter.
Two ways to skin it, but I'd stick with modern if I
were you.
