Can you guys help me with unlocking converter problem&code?
Old Apr 6, 2013 | 11:08 AM
justin hover's Avatar
Default Can you guys help me with unlocking converter problem&code?
Just had my tranny rebuilt with the 4k stall ...cam installed/dyno tuned.
When cruising at 55mph or anthing after lockup, my converter randomly unlocks then locks back up throughout driving,mostly after its warmed up. Kinda feels like a downshift.So if I'm cruising at 55mph at 1900rpm....it suddenly jumps to 2300rpm (unlocks I think).Then it will randomly lock back up.
It also recently threw the p0751 "shift solenoid "A" performance or off " Any help is much appreciated . I have a small window of time to correct these issue
Old Apr 6, 2013 | 07:48 PM
mrvedit's Avatar
Moderator
There have been several threads on similar problems.
Sometimes its as simple as making the brake pedal switch less sensitive to bumps in the road.
Old Apr 8, 2013 | 08:34 AM
slow67's Avatar
Gingervitis Addict
Also the PCM may be "detecting" misfires due to the smaller converter.
Old Apr 8, 2013 | 06:39 PM
Misfires were deleted during dyno tune. I'm left with a bunch of options but don't know where to start. Brake pedal...solenoid...other things I'm not familiar with. I just don't want to end up at the shop 2-3 more times paying more money seeing what works and what doesnt. I wasn't expecting this issue...thought a locking/unlocking converter was fool proof.
Now I'm stuck with a randomly locking..but mostly unlocked converter that is just killing my gas. I'm trying to come up with as many options as possible to do in one day at the shop...just not too sure which ones yet.
Old Apr 8, 2013 | 07:23 PM
mrvedit's Avatar
Moderator
Check how sensitive your brake pedal switch is to motion. With engine off, ignition on, have someone watch your brake lights while you push the brake pedal with your hand. If the brake lights turn on with only e.g. 1/8" of movement, that might be too sensitive. I would aim for at least 1/2"; there might be adjustment on the switch or a bracket to bend.
Yes, its a wild shot, but I am not making this up - this was the solution on at least two threads in the past year, describing the same problem.
Old Apr 8, 2013 | 11:11 PM
RevGTO's Avatar
Pontiacerator
There are a number of DTC's that have to be turned off with a higher stall converter. Otherwise they will give trouble like what you're experiencing, or cause the tranny to go into limp mode. Do you have the ability to continue to tune your car?
Old Apr 9, 2013 | 06:07 AM
No...I can only data log through my torque app. Can't remember everthing though I will call to refresh my memory but....torque managment is gone....line pressure is up (I need/am getting a shift kit) misfires deleted, tcc or tpp or something like that,, values were maxed out. What other tuning terminology should know about? Or bring up? I can always send my pcm back to my tuner to avoid the drive. When it was dyno tuned just a couple weeks ago everthing was fine. Then a couple drives later this started.
Old Apr 9, 2013 | 11:15 PM
RevGTO's Avatar
Pontiacerator
When I installed my TCI SF3000 stall, the only tuning I did was for driveability and performance. When I moved up to a Yank SS3600, I had problems with tranny going into limp mode and other issues and they were solved only by disabling reporting for certain codes. The PCM never threw an SES light.
Read the section on codes from this thread in the stickies https://ls1tech.com/forums/automatic...lush-more.html Some P075x codes and P1870 might need to be tuned to not report. I had to raise the threshold for misfire reporting in the low and mid rpm range for certain cells. I also had problems with a false P0502.
Old Apr 10, 2013 | 09:02 AM
slow67's Avatar
Gingervitis Addict
Not misfire codes, but there are 2 misfire tables you must max out.
Old Apr 10, 2013 | 10:48 PM
RevGTO's Avatar
Pontiacerator
Yes, that's what I was referring to.
Old Apr 12, 2013 | 07:44 PM
I thought 4l60s didn't have limp mode? I'm almost positive I've read that before.
Old Apr 12, 2013 | 08:13 PM
mrvedit's Avatar
Moderator
No, if you pull out the trans connector or the PCM detects a major problem the trans goes into "limp mode" which is 3rd gear. When both shift solenoids are off, it is 3rd gear.
Old Apr 12, 2013 | 08:33 PM
Thanks for clearing that up, Im thinking about replacing the solenoid for the PO751 code and going from their. Though I thought that was just for 1-2 shift stuck off, and my car shifts just fine. I did clear that code and it never came back on....just the damm converter unlocking/ locking 5 times in 10 miles..sometimes it didn't lock but once. I tried the brake switch with no difference. If its not that solenoid I'm gonna be pissed..were digging pools ***** to the wall and don't have anytime.
Old Apr 16, 2013 | 04:12 PM
joecar's Avatar
Can you log the brake pedal switch and misfire counter when TCC unlocks...?
Also there are pids that indicate the reason for unlocking the TCC.
Old Apr 16, 2013 | 05:38 PM
mrvedit's Avatar
Moderator
Justin: Having read many of your posts and noticing your interest in knowing all the details, you should spring for a full tuning package like HP Tuners.
As Joecar points out, you can then log various parameters and debug this problem.
However, I think you would really enjoy the engine engine tuning process, which really is a must as you make mods.
Old Apr 16, 2013 | 06:37 PM
joecar's Avatar
In EFILive you would look at the following pids to diagnose TCC unlock:
Code:
Status parameter {GM.TSTATE03}
Transmission State 03
(Bitmapped PID)
Description                             Status=0        Status=1
Unused                                  -               -
Cruise Control Status                   Off             On
Unused                                  -               -
Throttle Kickdown Mode Active           No              Yes
TCC Release Switch Status (4T40 only)   Off             Released
Fuel Power Enrichment Mode Active       No              Yes
A/C Clutch Status                       Off             On
Cruise/TCC Brake Switch                 Released        Depressed
Code:
Status parameter {GM.TSTATE09}
Transmission State 09
(Bitmapped PID)
TCC Off Due To Slip                     No              Yes
Unused                                  -               -
TCC Off Due To Downshift                No              Yes
TCC Off Due To Throttle Change          No              Yes
TCC Off Due To Brake On                 No              Yes
TCC Off Due To Cold Engine              No              Yes
TCC Off Due To Cold Transmission        No              Yes
TCC Off Due To Range                    No              Yes
Code:
Status parameter {GM.TSTATE10}
Transmission State 10
(Bitmapped PID)
TCC Fully Locked                        No              Yes
TCC Off Due To Misfire                  No              Yes
Unused                                  -               -
Unused                                  -               -
Unused                                  -               -
Unused                                  -               -
TCC Off Due To Minimum Throttle         No              Yes
TCC Off Due To Upshift                  No              Yes
Code:
Status parameter {GM.TSTATE12}
Transmission State 12
(Bitmapped PID)
Unused                                  -               -
Unused                                  -               -
Unused                                  -               -
TCC At Maximum Pressure                 No              Yes
3-2 Solenoid PWM >0%                    No              Yes
Shift Solenoid B state                  Off             On
Shift Solenoid A state                  Off             On
TCC State                               Off             On
Code:
Status parameter {GM.TCCMODE}
TCC Mode
(Enumerated PID)
Value   Caption Description
0       Off     TCC Off
1       Rel     TCC Releasing
2       App     TCC Applying
3       AppEn   TCC Apply Enabled
4       Lock    TCC Locked
5       Coast   TCC Coast
6       Slew    TCC Slewed
Old Apr 16, 2013 | 07:22 PM
mrvedit's Avatar
Moderator
Nice doco Joecar. I didn't know there were bitmapped PIDs. I have not seen them documented in HP Tuners, but I suspect they can be accessed.
Justin: That should give you some idea of how much additional information is available when scanning with EFILive (and perhaps also with HP Tuners).
There are 10 kinds of people in this world - those who understand binary (bitmapped) numbers and those who don't.
Old Apr 16, 2013 | 10:38 PM
joecar's Avatar
mrvedit, lol at your sig
Old Jun 22, 2013 | 01:03 AM
lemons12's Avatar
PWM issue possibly..
