Weak lock up on new converter
But the lock up clutch, since the first time I drove the car, has been very weak. Say I'm merging into the freeway at 3500rpm 50 mph, if it tries to lock up, you just feel it pulling but not getting it to actually lock up. Ill have to let off the gss to let it engage. If I'm just cruising at 50 2500 rpm, the lock up won't be the hard jolt everyone else is a getting, it takes about a full second, maybe a second and a half, for it to lock up from 2500 rpm. Seems and feels like the clutch isn't grabbing enough. I can press on the gas during lockup and it'll slip about 75-125 rpm, and no that's not it unlocking. If it unlocked the rpms would flash up by about 1500. Big difference.
I was wondering if this is a problem with my line pressure or just a bad converter?
pressure for small diameter lockup clutches - if
you scan you will see 0% on the highway. Don't
know just how high the pedal has to go before it
adds any.
And if you have any "TCC Slip Learning" going on,
the TCC duty can knock it down from the already-
too-low main line pressure.
Put TCC duty to 98% min, 99% max first. That will
eliminate the "learning" (meant to shed pump load
until "just barely slips").
If you still have trouble then reach into the Force
Motor Positive table, or touch up the General Pressure
stuff that bumps up line when TCC is applied (if your
vehicle has this supported - some do, some don't).
This was enough to get my fried TCI drivable even
after ruining the clutch with Trick Shift fluid. Not great,
but would hold on on-ramps and such where before
touching the tune it'd hoot and howl up mild grades
before popping the slip-code.
So, most likely, this problem isn't from an inferior converter? Its a 10.5" unit. Not as small as the 8 and 9" ones but definitely not the 12" stock unit.
Hell tune wise I was wanting to minimize lock up, its irritating sometimes. Having it lock up while you're generously on the gas getting on the freeway is ridiculous. I really only want it to lock when I'm not really accelerating at all.
