What ATF you running?
Should I just grab the stock stuff from GM? Or is there something else you'd suggest? What about the cheap stuff from wally world? The car is just a summer time daily driver, not a track car.
Also, the car has 156k on it. I doubt its the original trans, or it's at least been rebuilt sometime in its life.
Thanks!
In the past I've always used a cheaper brand from Parts Plus and never had any issues. Topped it off with some Oreilley's brand before and that stuff seemed a lighter shade of pink and maybe even a little thinner. Might be fine but I stopped using it.
However I only Dexron 6 because I don't mind paying a bit more and I use it with newly rebuilt transmissions.
I have no facts, but I agree with novaflash2002 about not mixing Dex 3 and Dex 6 unnecessarily.
I think the majority of members here are running Dex 3 with no problems and there is little evidence that Dex 6 is any better; just more expensive. Dex 6 might last 100,000+ miles, but most members are going to replace the trans fluid every few years (e.g. 25,000) anyway.
In short, unless you are rebuilding a trans and don't want to change fluid for 100,000+ miles, just use a quality Dex 3.
